<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Lock sets for read access
Date: Wed, 30 Nov 1994 13:03:36 -0600
> From [email protected] Wed Nov 30 12:37 CST 1994
> Date: Wed, 30 Nov 94 12:36:37 CST
> From: [email protected] (Tim Mooney)
> To: [email protected], [email protected]
> Content-Type> : > text>
> Content-Length: 633
> re...
> > From [email protected] Tue Nov 22 17:53:05 1994
> > > From [email protected] Tue Nov 22 08:35 CST 1994
> > > So, my thoughts are:
> > > 1) Do lock sets inhibit read access as well as write and process access?
> > Starting with 3.12 reads from outside the database, i.e. from channel access,
> > lock. Previously this was not true. Note however that each individual read
> > locks. Thus if you have a series of ca_gets you will not get what you want.
> Could you clarify that?  If a read is attempted while a record is locked
> because a member of its lock set is processing, does the read pend until
> the lock goes away?
> Tim Mooney
Yes the read does pend
Marty Kraimer
Prev: Re: Lock sets for read access Tim Mooney
Next: IOC memory leak Matt Bickley
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Release Numbers Steve Lewis
