Subject: |
devLib, locationProbe routine |
Andrew Johnson <[email protected]> |
Date: |
Wed, 26 Oct 1994 13:19:11 BST |
Am I right in thinking that the routine locationProbe in devlib returns
SUCCESS to indicate that the given address does *not* respond to VME accesses of
any size? I presume the aim here is to indicate that this area of the memory
map is currently not used.
Should I be using this in my driver to check that a board is present? The older
drivers use vxMemProbe, which returns OK if something responds. It seems wrong
to expect an error code (S_dev_addressOverlap) as the status return indicating
success (ie board found), which is what I would have to do if I used the
locationProbe routine.
Are there plans to modify the existing drivers to use the devLib facilities?
- Andrew
,_}\_. Andrew Johnson, Technology Division
/ \ Royal Greenwich Observatory
~~~~~~~~| ,--/;. )~~~~ Madingley Road, Cambridge, UK
., |/ (/ U Phone: +44 (0)1223 374823
.`., /_\ . . Net: [email protected]
wwWWWww' WWW: http://cast0.ast.cam.ac.uk/~anj/
get_convert_table and DBF_STRING sources mcgehee
Re: devLib, locationProbe routine Andrew Johnson
<1994>
Re: get_convert_table and DBF_STRING sources Marty Kraimer
<1994>
