<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Changes to Stepper Motor Record
Date: Tue, 28 Jun 94 09:47:22 CDT
Andrew writes:
> Various people have been talking about making modifications to the stepper motor
> record.  Would anyone doing this have time to add a couple of enhancements which
> probably have widespread use?
If there are other motor control features that would be useful please let me know.
> 1. Simulation fields - as far as I can make out this record type only works when
> there is hardware present.
The only problem I have found with running the record without motors(assuming OMS
boards) is when the board is configured for active high limit switches. The limit
switchs can be disabled in software so implementing this feature should be
straight foreward. A workaround is to change the limit switch configuration to
active low (jumpers in).
> 2. Support for the Home sensor (datum switch), which I know can be connected to
> the OMS card.
The Home sensor function is already implemented in the 'new' motor record.
	Joe
Joseph P. Sullivan                     Phone:    (708) 252-8657
Experimental Facilities Division       Internet: [email protected]
Argonne National Laboratory            Fax:      (708) 252-3222
9700 S. Cass Ave. Bldg. 362
Argonne, IL  60439-4844
Prev: Changes to Stepper Motor Record Andrew Johnson
Next: Re: Channel access Jeff Hill
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
