<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: OMS VME-8 motor controllers: PAL upgrades
Date: Fri, 17 Jun 94 12:55:41 CDT
Bob writes:
>   I am not sure what version of the OMS driver is in use by the CAT's, but the
>   original driver uses the interupts to get data back from the OMS.
This facility must have been taken out  of the device driver when the
Tim's "new" motor was created. I am going to take a look at putting it
back in.
>   I would be very interested in beta testing their PAL. I was too quick to
>   delete that message - could someone give me a contact at OMS?
I received 5 the beta version BUS4G PAL for our latest batch of
OMS VME8 boards from Steve Flago (VP Engineering). I have been working
on test code to see if the interrupts are fulling functional since our
motor record does not use them.
>   Is this only available on the OMS-8? To date, we've been able to use the
>   same driver for all of their cards.
The BUS4G PAL is only for the VME8. I don't know if the problem it fixes
is also present on the other models.
	Joe
Prev: OMS VME-8 motor controllers: PAL upgrades Bob Dalesio
Next: Re: CA problem from Vax Jeff Hill
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: OMS VME-8 motor controllers: PAL upgrades Joseph P. Sullivan
