<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: vxi device support/record support parameters
Date: Thu, 9 Jun 94 16:25:42 CDT
Does anyone know why a VXI_IO type device has inputs for signal and
parameter but only the parameter value gets used in the device code
(see devVxiTDM.c).  If you look in the above listing, the parameter
field of structure vxiio is used as a char input.  Why???  Then, this
gets converted into an integer that is THEN the signal (i.e., channel)
used to define a hardware channel (per card).
This gets even more nebulous when you are prompted for both the signal
and parameter when a VXI_IO type record is created.
Was this designed with a specific VXI device in mind because none of
ours work this way?
Bob Cleaves
Kinetics
([email protected])
Prev: Re: BITBUS and PC's Tim Mooney
Next: Re: BITBUS and PC's Jeff Hill
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: BITBUS and PC's Jeff Hill
Next: vxWorks Bob Dalesio
