<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: PV names
Date: Fri, 27 May 94 15:44:52 MDT
Bill writes :
<What characters are allowable in PV names?  If there is a document that
<spells out the restrictions, could some kind soul pas me a pointer?
and the failing example is
    BL09.0%PLC%BM00%EPS
The character "." is a special one in EPICS because it is used to
separate the record name and field name.
When dbFindRecord is called it does:
  while (*precordName && (*precordName != '.') && (lenName < PVNAME_SZ)){
	        *pconvName++ = *precordName++;
        lenName++;
i.e. it's looking for the "." as the end of the record name, so that pretty much
makes "." a character to avoid in pv names.  ":" and "_" work in names--could you
possibly substitute one of those.  It doesn't look like anything else is illegal,
but I wouldn't put money on it just yet. And don't forget the limitation on length.
	Deb
Prev: Re: Reflections on a Reflective Memory Device Interface Bill Brown
Next: Re: PV names Bill Brown
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: PV names Bill Brown
