<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Logical Naming of Hardware Addresses
Date: Wed, 25 May 1994 07:38:09 -0700
Chip writes:
> Proliferation of files is a bad idea.  If you have enough reflective memory,
> you could use dynamic allocation, and include a hash table in the reflective
> memory to look up names.  All IOC's would first look up the name, and if it
> did not exist, would add it dynamically.  A semaphore (soft or hard, depending
> upon what the hardware supports) would protect the hash table.
I would agree that 'profileration' of files is a bad idea but there seem to
cases in which it is practical for the IOC-based records to interact with
the host via the filesystem.
Current cases include:
	The reading of a JEDEC fuse map during PAL record initialization.
	The writing of image data files by the EPICS Video system.
In the case of complex record types at what point does the number (or desired
run-time flexibility) of the fields really beg for a configuration file to
exist somewhere (host disk, local disk, NVRAM, whatever)?
Peregrine
Prev: Re: Logical Naming of Hardware Addresses Andrew Johnson
Next: [none given] greene%denali.UUCP
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Logical Naming of Hardware Addresses mrk
