<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: applications that use channel access
Date: Wed, 27 Apr 94 09:48:59 MDT
Hello All,
John Winans writes:
> For those applications (like burt, and the device abstraction stuff Claude
> has been working on) that only want to know the value on a one-shot basis,
> I would think that getting the value on the connect would be more efficient
> than otherwise.
> What is going to be the generally accepted way to do that sort of thing
> anyway?  Is there going to be some special kind of call for it?  Or are
> they going to actually going to build a connection and then close it again?
Applications like "burt, and the device abstraction stuff
Claude has been working on" will normally need to fetch values
from several channels on the same IOC. This implies that the
virtual circuit setup overhead as a percentage of the total
labor for N channel value fetch requests might often be
insignificant.
It is possible that connectionless get/put requests would be
a useful addition to channel access. They would be an
efficient choice when a single batch of gets/puts needed to be
performed infrequently to a single IOC. They would be a poor
choice for high throughput, ordered delivery dependent, or IOC
state change (monitor) driven applications. I will keep this
under consideration for EPICS V4 CA.
This does not change my resolve to eliminate the connectionless
get capability that can currently be combined with the CA request
to create a virtual circuit as described in the original source of
this thread of discussion. So far I have not received a response from
anyone that is using it.
Jeff
______________________________________________________________________
Jeffrey O. Hill			Internet	[email protected]
LANL MS H820			Voice		505 665 1831
Los Alamos, NM USA 87545	FAX		505 665 5107
Prev: Re: applications that use channel access John R. Winans
Next: Re: applications that use channel access winans
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
