2012  2013  2014  2015  2016  <20172018  2019  Index 2012  2013  2014  2015  2016  <20172018  2019
Subject: EPUCS Qt release 3.5.1
To: "'[email protected]'" <[email protected]>
Date: Fri, 7 Jul 2017 08:36:55 +0000
Dear all,
We would like to announce the release of EPICS Qt release 3.5.1
This is available at https://github.com/qtepics with guidance notes
The main change in this release is that the QEPlugin library has been split the
into two distinct libraries which are:
  QEFramework - the functional library which contains the widgets themselves
                together with support functionality. qegui and any other bespoke
                display managers programs will need to link against this library.
  QEPlugin - strictly the widget plugin library usable by any application using
             the ui loader, such as qegui and designer. The QEPlugin library is
             dependent on the QEFramework library.
Both libraries are part of the qeframework repository.
The release notes, located at https://qtepics.github.io/release_notes.html , go into
further detail.
Regards
Andrew C. Starritt | Principal Controls Engineer | Australian Synchrotron
p: (03) 8540 4164 | f: (03) 8540 4200
[email protected] | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
Prev: epicsQt release 3.4.3 - at GitHub Andrew C. Starritt
Next: EPICS Qt release 3.5.1 Andrew C. Starritt
Index: 2012  2013  2014  2015  2016  <20172018  2019
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
