2012  2013  2014  2015  <20162017  2018  2019  Index 2012  2013  2014  2015  <20162017  2018  2019
Subject: RE: epics4
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Thu, 29 Sep 2016 12:59:33 +0000
Hi Anton,
You must be using a very old version of EPICS V4. I think 4.3 was the last release to have that API, so if that’s the case you may have to look out for a few other changes (pva network protocol changed between 4.3. and 4.4).
To create a pvRequest you just supply the request string – there’s no need to supply a requester. createRequest() simply takes the string and returns the corresponding PVStructure.
Note since 4.3 CreateRequest has moved from pvAccess to pvData and the singleton instance getCreateRequest() has been replace by a static create().
So
pvRequestP = getCreateRequest()->createRequest(request, requesterP);
becomes
pvRequestP = CreateRequest::create()->createRequest(request);
If the createRequest was the only reason for creating the requesters then you won’t need them anymore.
Note that createRequest throws std::logic_exceptions with helpful messages if something goes wrong.
Hope that helps,
Dave
From: [email protected] [mailto:[email protected]] On Behalf Of Mezger Anton Christian (PSI)
Sent: 28 September 2016 17:08
To: [email protected]; [email protected]
Subject: epics4
In a previous version of EPICS4 I had to use the following code at initialization
    Requester::shared_pointer requesterP(new RequesterImpl("pvput"));
    Requester::shared_pointer requesterG(new RequesterImpl("pvget"));
    pvRequestG = getCreateRequest()->createRequest(request, requesterG);
    if(pvRequestG.get()==NULL) printf("failed to parse request string\n");
    if(pvRequestP.get()==NULL) printf("failed to parse request string\n");
However in the latest version createRequest only takes one argument. How to do it now?
Best regards
Anton
epics4 Mezger Anton Christian (PSI)
Prev: epics4 Mezger Anton Christian (PSI)
Next: Status of EPICS and Qt Andrew Johnson
Index: 2012  2013  2014  2015  <20162017  2018  2019
ANJ, 03 Jan 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
