Argonne National Laboratory
2012  2013  2014  <20152016  2017  Index 2012  2013  2014  <20152016  2017
Subject: QEForm
To: Andrew Rhyder <Andrew.Rhyder@synchrotron.org.au>, "Dunning, Michael" <mdunning@slac.stanford.edu>, "qti-talk@aps.anl.gov" <qti-talk@aps.anl.gov>
Date: Thu, 16 Apr 2015 12:31:50 -0700
Hi Andrew,
I finally got a chance to return to my issue with QEForm.
Description of problem:
A typical usage of QEForm widget is to display a ui file created with designer. Often I need to have access to a widget, which is a child of the ui object, from the parent of the QEForm object.
This is what I have done to test how this could be accomplished.
1. I modified QEForm.h file where I added a public function
    QWidget* getUiHandle(){ return(ui);}
2. In my test program I can then get address of the widget in question using
    MyWidget* mywidget=qeform->findChild<MyWidget*>("mywidgetobjectname");
This works, but there is no convenient way to tell when the ui pointer in QEForm object gets a valid address.
I am asking if you could make the following modification to QEForm:
1. add a public function to QEForm.h, something like what I did for testing.
2. add a signal which would be emitted when QEForm is ready for action.
Thank you Andrew,
Zen
Prev: epicsqt and caQtDM Andrew Rhyder
Next: Re: QEForm Zenon Szalata
Index: 2012  2013  2014  <20152016  2017
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
