Hi Andrew, no problem. Should we then „retire“ Launchpad and fully
switch to GitHub? I find it confusing to have multiple bug trackers for
the same project.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/2052814
Title:
dbLoadRecords with subs=NULL fails to expand macros with defaults
Status in EPICS Base:
Confirmed
Bug description:
A template file that only contains macros with default values can be
loaded with `dbLoadRecords("file.db","")` but not with
`dbLoadRecords("file.db",NULL)`. In particular, in the startup script,
it cannot be loaded with `dbLoadRecords "file.db"` but only with
`dbLoadRecords "file.db",""`. (VxWorks shell as well as iocsh.)
Using such a macro in a record name results in the error message:
ERROR: Bad character '$' in Record/Alias name "$(P=)Name"
Using macros with defaults in fields shows error messages like this:
ERRORName.PREC Has unexpanded macro
Can't set "Name.PREC" to "$(PREC=3)" : Bad Field value
ERRORERROR failed to load 'file.db'
(Unrelated: Someone please fix the missing blanks after ERROR and the
ERRORERROR.)
The reason is that `dbReadCOM`, the function that does the real work,
only creates a `macHandle` when `substitutions` is not `NULL`. Not
having a `macHandle` prevents any macro substitution from working,
even those which provide a default value.
In the old times, when macros could not have defaults, this was fine,
but not any more. A macro handle should always be created, even if it
stays empty when `substitutions` is `NULL`.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/2052814/+subscriptions
- [Bug 2052814] [NEW] dbLoadRecords with subs=NULL fails to expand macros with defaults Dirk Zimoch via Core-talk
[Bug 2052814] Re: dbLoadRecords with subs=NULL fails to expand macros with defaults Andrew Johnson via Core-talk
Build failed: epics-base base-win32_static_set_thread_names-55 AppVeyor via Core-talk
<2024>
[Bug 2052814] Re: dbLoadRecords with subs=NULL fails to expand macros with defaults Dirk Zimoch via Core-talk
<2024>
