Am 12.01.21 um 19:04 schrieb Andrew Johnson:
> That test passes on the current 7.0 branch, so something in your
> refactoring may have been developed based on an assumption that
> Dirk's array code invalidated
Possibly. I vaguely remember that I had to jump through a few hoops to
get certain calls to fail on zero sized array requests, since the tests
specified it this way. I'll have to find those hoops and crawl back out...
https://code.launchpad.net/~bfrk/epics-base/+git/epics-base/+merge/396197
Your team EPICS Core Developers is requested to review the proposed merge of ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0.
Build failed in Jenkins: EPICS-3.14 #909 Jenkins EPICS PSI via Core-talk
Build failed: EPICS Base 7 base-7.0-122 AppVeyor via Core-talk
<2021>
Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
<2021>
