Subject: |
Build failed in Jenkins: epics-base-3.15-win32s-test #215 |
APS Jenkins via Core-talk <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 27 Feb 2019 11:54:24 -0600 (CST) |
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-win32s-test/215/display/redirect>
Started by upstream project "epics-base-3.15-win32s" build number 374
originally caused by:
Started by upstream project "epics-base-3.15-win32" build number 381
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win32-2 (win32-x86) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.15-win32s-test/ws/>
[epics-base-3.15-win32] $ sh.bat C:\Users\jenkins\AppData\Local\Temp\jenkins1178999441546690329.sh
The system cannot find the file specified
FATAL: command execution failed
java.io.IOException: CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.<init>(Unknown Source)
at java.lang.ProcessImpl.start(Unknown Source)
Also: hudson.remoting.Channel$CallSiteStackTrace: Remote call to win32-2
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1741)
at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
at hudson.remoting.Channel.call(Channel.java:955)
at hudson.Launcher$RemoteLauncher.launch(Launcher.java:1059)
at hudson.plugins.cygpath.CygpathLauncherDecorator$1.launch(CygpathLauncherDecorator.java:66)
at hudson.Launcher$ProcStarter.start(Launcher.java:455)
at hudson.tasks.CommandInterpreter.perform(CommandInterpreter.java:109)
at hudson.tasks.CommandInterpreter.perform(CommandInterpreter.java:66)
at hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:20)
at hudson.model.AbstractBuild$AbstractBuildExecution.perform(AbstractBuild.java:744)
at hudson.model.Build$BuildExecution.build(Build.java:206)
at hudson.model.Build$BuildExecution.doRun(Build.java:163)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:504)
at hudson.model.Run.execute(Run.java:1810)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:429)
Caused: java.io.IOException: Cannot run program "sh.bat" (in directory "C:\jenkins\win32-2\workspace\epics-base-3.15-win32"): CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessBuilder.start(Unknown Source)
at hudson.Proc$LocalProc.<init>(Proc.java:249)
at hudson.Proc$LocalProc.<init>(Proc.java:218)
at hudson.Launcher$LocalLauncher.launch(Launcher.java:936)
at hudson.Launcher$RemoteLaunchCallable.call(Launcher.java:1313)
at hudson.Launcher$RemoteLaunchCallable.call(Launcher.java:1266)
at hudson.remoting.UserRequest.perform(UserRequest.java:212)
at hudson.remoting.UserRequest.perform(UserRequest.java:54)
at hudson.remoting.Request$2.run(Request.java:369)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Build step 'Execute shell' marked build as failure
- Jenkins build is back to normal : epics-base-3.15-win32s-test #216 APS Jenkins via Core-talk
Build failed in Jenkins: epics-base-3.15-win32-test #205 APS Jenkins via Core-talk
Jenkins build is back to normal : epics-base-3.15-win32-test #206 APS Jenkins via Core-talk
<2019>
<2019>
