> -----Original Message-----
> From: Michael Davidsaver [mailto:[email protected]]
> Sent: Wednesday, December 27, 2017 5:44 PM
> To: Mark Rivers
> Cc: 'Andrew Johnson'; [email protected]
> Subject: Re: Problem building example application on windows-x64
> On 12/27/2017 03:15 PM, Mark Rivers wrote:
> > Is there a test in EPICS base that instantiates the example IOC?
> No, though I'm going to go way out on a limb here and guess that
> there are other things we're not doing which would have caught
> some of this earlier.
> Do the unit-tests pass for you?
> > make runtests
In fact there are lots of failures in the unit-tests.
This is my configuration
EPICS_HOST_ARCH=windows-x64-static
VS2010
Added HOST_OPT=NO to CONFIG_SITE.Common.windows-x64-static
The tests below which say "Can't spawn" popped up a Windows dialog box saying the program had crashed. There were also a number of tests which popped up dialog boxes saying an Assert had failed.
H:\epics-devel\base-7.0.1>make -s runtests
Snippets.t .. ok
All tests successful.
Files=1, Tests=29, 2 wallclock secs ( 0.00 usr + 0.00 sys = 0.00 CPU)
Result: PASS
epicsUnitTestTest.t ........ ok
epicsTypesTest.t ........... ok
epicsInlineTest.t .......... ok
epicsCalcTest.t ............ ok
epicsAlgorithmTest.t ....... ok
epicsMathTest.t ............ ok
epicsMMIOTest.t ............ ok
epicsEllTest.t ............. ok
epicsEnvTest.t ............. ok
epicsErrlogTest.t .......... 24/32 log client: connected to log server at "127.0.0.1:51590"
epicsErrlogTest.t .......... ok
epicsStdioTest.t ........... ok
epicsStdlibTest.t .......... ok
epicsSockResolveTest.t ..... ok
epicsStringTest.t .......... ok
epicsTimeTest.t ............ ok
epicsTimeZoneTest.t ........ ok
epicsThreadTest.t .......... ok
epicsThreadOnceTest.t ...... ok
epicsThreadPriorityTest.t .. ok
epicsThreadPrivateTest.t ... ok
epicsThreadHooksTest.t ..... ok
epicsThreadPoolTest.t ...... ok
epicsExitTest.t ............ ok
epicsTimerTest.t ........... ok
ringPointerTest.t .......... ok
ringBytesTest.t ............ ok
epicsEventTest.t ........... ok
epicsMutexTest.t ........... ok
epicsSpinTest.t ............ ok
epicsAtomicTest.t .......... ok
macDefExpandTest.t ......... ok
cvtFastTest.t .............. ok
macLibTest.t ............... ok
macLib.t ................... ok
taskwdTest.t ............... ok
blockingSockTest.t ......... ok
epicsMessageQueueTest.t .... ok
epicsStackTraceTest.t ...... ok
ipAddrToAsciiTest.t ........ ok
osiSockTest.t .............. ok
Test Summary Report
epicsMathTest.t (Wstat: 0 Tests: 35 Failed: 0)
TODO passed: 8-9, 11-12, 22-23
Files=40, Tests=4016, 203 wallclock secs ( 0.34 usr + 0.12 sys = 0.47 CPU)
Result: PASS
dbScanTest.t ............... ok
dbShutdownTest.t ........... ok
dbPutLinkTest.t ............ 265/320 dbJLinkInit: lexical error: invalid char in json text.
{"x":bbbb}
(right here) ------^
dbJLinkInit: parse error: premature EOF
{"z":{"good":6}
dbPutLinkTest.t ............ ok
dbLockTest.t ............... ok
dbStressTest.t ............. ok
testdbConvert.t ............ ok
callbackTest.t ............. ok
callbackParallelTest.t ..... ok
dbStateTest.t .............. ok
dbServerTest.t ............. dbRegisterServer: 'one' registered twice?
dbServerTest.t ............. 1/24 dbRegisterServer: Bad server name 'bad name'
dbRegisterServer: Ignoring 'disabled', per environment
dbUnregisterServer: Servers still active!
dbUnregisterServer: 'toolate' not registered.
dbUnregisterServer: 'no-routines' has no stop() method.
dbServerTest.t ............. ok
dbCaStatsTest.t ............ ok
dbCaLinkTest.t ............. ok
scanIoTest.t ............... ok
dbChannelTest.t ............ ok
dbChArrTest.t .............. Starting iocInit
dbChArrTest.t .............. ok
chfPluginTest.t ............ 1/1433 chfConfigParseStart: plugin pvt alloc failed
chfPluginTest.t ............ ok
arrShorthandTest.t ......... ok
recGblCheckDeadbandTest.t .. ok
testPutGetTest.t ........... ok
dbStaticTest.t ............. ok
Files=20, Tests=2856, 82 wallclock secs ( 0.39 usr + 0.11 sys = 0.50 CPU)
Result: PASS
msi.t .. ok
Files=1, Tests=9, 0 wallclock secs ( 0.00 usr + 0.00 sys = 0.00 CPU)
Result: PASS
arrayOpTest.t ........... ok
recMiscTest.t ........... ok
linkRetargetLinkTest.t .. ok
linkInitTest.t .......... 1/77 dbRegisterServer: 'rsrv' registered twice?
linkInitTest.t .......... 8/77 dbRegisterServer: 'rsrv' registered twice?
linkInitTest.t .......... 32/77 dbRegisterServer: 'rsrv' registered twice?
linkInitTest.t .......... 60/77 dbRegisterServer: 'rsrv' registered twice?
linkInitTest.t .......... ok
compressTest.t .......... 1/116 dbRegisterServer: 'rsrv' registered twice?
compressTest.t .......... ok
asyncSoftTest.t ......... ok
softTest.t .............. ok
asTest.t ................ ok
analogMonitorTest.t ..... Starting iocInit
analogMonitorTest.t ..... ok
regressTest.t ........... 1/31 dbRegisterServer: 'rsrv' registered twice?
dbConvertJSON: parse error: trailing garbage
0x10
0x10
0x10
0x10
0x10
0x10
0x10
0x10
regressTest.t ........... 6/31 dbRegisterServer: 'rsrv' registered twice?
regressTest.t ........... ok
simmTest.t .............. Failed 1/1176 subtests
Test Summary Report
simmTest.t (Wstat: 0 Tests: 1176 Failed: 1)
Failed test: 140
Files=11, Tests=3575, 15 wallclock secs ( 0.52 usr + 0.00 sys = 0.52 CPU)
Result: FAIL
Failed 1/11 test programs. 1/3575 subtests failed.
tsTest.t .... ok
dbndTest.t .. ok
arrTest.t ... ok
syncTest.t .. ok
Files=4, Tests=1612, 3 wallclock secs ( 0.22 usr + 0.00 sys = 0.22 CPU)
Result: PASS
Base.t ........ ok
Breaktable.t .. ok
DBD.t ......... ok
Device.t ...... ok
Driver.t ...... ok
Function.t .... ok
Menu.t ........ ok
Recfield.t .... ok
Recordtype.t .. ok
Registrar.t ... ok
Variable.t .... ok
Files=11, Tests=287, 1 wallclock secs ( 0.13 usr + 0.02 sys = 0.14 CPU)
Result: PASS
testThread.t ............ ok
testEvent.t ............. ok
testTimer.t ............. ok
testBitSet.t ............ ok
testOverrunBitSet.t ..... Can't spawn "./testOverrunBitSet.exe": No error at testOverrunBitSet.t line 12.
Can't run testOverrunBitSet.exe:
testOverrunBitSet.t ..... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
testByteBuffer.t ........ ok
testBaseException.t ..... ok
testSharedVector.t ...... ok
testDebugPtr.t .......... ok
testSerialization.t ..... ok
testTimeStamp.t ......... ok
testQueue.t ............. ok
testTypeCast.t .......... ok
testUnitTest.t .......... ok
testjson.t .............. Can't spawn "./testjson.exe": No error at testjson.t line 12.
Can't run testjson.exe:
testjson.t .............. Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
test_reftrack.t ......... ok
testanyscalar.t ......... ok
testBitSetUtil.t ........ ok
testIntrospect.t ........ ok
testPVType.t ............ ok
testStandardField.t ..... Can't spawn "./testStandardField.exe": No error at testStandardField.t line 12.
Can't run testStandardField.exe:
testStandardField.t ..... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
testStandardPVField.t ... Can't spawn "./testStandardPVField.exe": No error at testStandardPVField.t line 12.
Can't run testStandardPVField.exe:
testStandardPVField.t ... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
testPVData.t ............ ok
testPVUnion.t ........... Can't spawn "./testPVUnion.exe": No error at testPVUnion.t line 12.
Can't run testPVUnion.exe:
testPVUnion.t ........... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
testConvert.t ........... ok
testPVScalarArray.t ..... ok
testPVStructureArray.t .. ok
testOperators.t ......... Can't spawn "./testOperators.exe": No error at testOperators.t line 12.
Can't run testOperators.exe:
testOperators.t ......... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
testFieldBuilder.t ...... ok
testValueBuilder.t ...... Can't spawn "./testValueBuilder.exe": No error at testValueBuilder.t line 12.
Can't run testValueBuilder.exe:
testValueBuilder.t ...... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
testProperty.t .......... ok
testCreateRequest.t ..... Can't spawn "./testCreateRequest.exe": No error at testCreateRequest.t line 12.
Can't run testCreateRequest.exe:
testCreateRequest.t ..... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
testPVCopy.t ............ Can't spawn "./testPVCopy.exe": No error at testPVCopy.t line 12.
Can't run testPVCopy.exe:
testPVCopy.t ............ Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
Test Summary Report
testOverrunBitSet.t (Wstat: 65280 Tests: 0 Failed: 0)
Non-zero exit status: 255
Parse errors: No plan found in TAP output
testjson.t (Wstat: 65280 Tests: 0 Failed: 0)
testStandardField.t (Wstat: 65280 Tests: 0 Failed: 0)
testStandardPVField.t (Wstat: 65280 Tests: 0 Failed: 0)
testPVUnion.t (Wstat: 65280 Tests: 0 Failed: 0)
testOperators.t (Wstat: 65280 Tests: 0 Failed: 0)
testValueBuilder.t (Wstat: 65280 Tests: 0 Failed: 0)
testCreateRequest.t (Wstat: 65280 Tests: 0 Failed: 0)
testPVCopy.t (Wstat: 65280 Tests: 0 Failed: 0)
Files=33, Tests=1932, 370 wallclock secs ( 0.36 usr + 0.03 sys = 0.39 CPU)
Result: FAIL
Failed 9/33 test programs. 0/1932 subtests failed.
testAtomicBoolean.t ..... ok
testHexDump.t ........... ok
testInetAddressUtils.t .. ok
configurationTest.t ..... ok
testFairQueue.t ......... ok
testWildcard.t .......... ok
testChannelAccess.t ..... Can't spawn "./testChannelAccess.exe": No error at testChannelAccess.t line 12.
Can't run testChannelAccess.exe:
testChannelAccess.t ..... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
testCodec.t ............. Can't spawn "./testCodec.exe": No error at testCodec.t line 12.
Can't run testCodec.exe:
testCodec.t ............. Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
testRPC.t ............... Can't spawn "./testRPC.exe": No error at testRPC.t line 12.
Can't run testRPC.exe:
testRPC.t ............... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
testServerContext.t ..... Can't spawn "./testServerContext.exe": No error at testServerContext.t line 12.
Can't run testServerContext.exe:
testServerContext.t ..... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
Test Summary Report
testChannelAccess.t (Wstat: 65280 Tests: 0 Failed: 0)
testCodec.t (Wstat: 65280 Tests: 0 Failed: 0)
testRPC.t (Wstat: 65280 Tests: 0 Failed: 0)
testServerContext.t (Wstat: 65280 Tests: 0 Failed: 0)
Files=10, Tests=152, 7 wallclock secs ( 0.09 usr + 0.06 sys = 0.16 CPU)
Result: FAIL
Failed 4/10 test programs. 0/152 subtests failed.
ntfieldTest.t ............... Can't spawn "./ntfieldTest.exe": No error at ntfieldTest.t line 12.
Can't run ntfieldTest.exe:
ntfieldTest.t ............... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
ntscalarTest.t .............. Can't spawn "./ntscalarTest.exe": No error at ntscalarTest.t line 12.
Can't run ntscalarTest.exe:
ntscalarTest.t .............. Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
ntscalarArrayTest.t ......... Can't spawn "./ntscalarArrayTest.exe": No error at ntscalarArrayTest.t line 12.
Can't run ntscalarArrayTest.exe:
ntscalarArrayTest.t ......... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
ntnameValueTest.t ........... Can't spawn "./ntnameValueTest.exe": No error at ntnameValueTest.t line 12.
Can't run ntnameValueTest.exe:
ntnameValueTest.t ........... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
ntmultiChannelTest.t ........ Can't spawn "./ntmultiChannelTest.exe": No error at ntmultiChannelTest.t line 12.
Can't run ntmultiChannelTest.exe:
ntmultiChannelTest.t ........ Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
ntscalarMultiChannelTest.t .. Can't spawn "./ntscalarMultiChannelTest.exe": No error at ntscalarMultiChannelTest.t line 12.
Can't run ntscalarMultiChannelTest.exe:
ntscalarMultiChannelTest.t .. Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
nttableTest.t ............... Can't spawn "./nttableTest.exe": No error at nttableTest.t line 12.
Can't run nttableTest.exe:
nttableTest.t ............... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
ntndarrayTest.t ............. Can't spawn "./ntndarrayTest.exe": No error at ntndarrayTest.t line 12.
Can't run ntndarrayTest.exe:
ntndarrayTest.t ............. Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
ntmatrixTest.t .............. Can't spawn "./ntmatrixTest.exe": No error at ntmatrixTest.t line 12.
Can't run ntmatrixTest.exe:
ntmatrixTest.t .............. Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
ntenumTest.t ................ Can't spawn "./ntenumTest.exe": No error at ntenumTest.t line 12.
Can't run ntenumTest.exe:
ntenumTest.t ................ Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
ntunionTest.t ............... Can't spawn "./ntunionTest.exe": No error at ntunionTest.t line 12.
Can't run ntunionTest.exe:
ntunionTest.t ............... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
ntaggregateTest.t ........... Can't spawn "./ntaggregateTest.exe": No error at ntaggregateTest.t line 12.
Can't run ntaggregateTest.exe:
ntaggregateTest.t ........... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
ntattributeTest.t ........... Can't spawn "./ntattributeTest.exe": No error at ntattributeTest.t line 12.
Can't run ntattributeTest.exe:
ntattributeTest.t ........... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
ntndarrayAttributeTest.t .... Can't spawn "./ntndarrayAttributeTest.exe": No error at ntndarrayAttributeTest.t line 12.
Can't run ntndarrayAttributeTest.exe:
ntndarrayAttributeTest.t .... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
ntcontinuumTest.t ........... Can't spawn "./ntcontinuumTest.exe": No error at ntcontinuumTest.t line 12.
Can't run ntcontinuumTest.exe:
ntcontinuumTest.t ........... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
nthistogramTest.t ........... Can't spawn "./nthistogramTest.exe": No error at nthistogramTest.t line 12.
Can't run nthistogramTest.exe:
nthistogramTest.t ........... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
ntutilsTest.t ............... ok
Test Summary Report
ntfieldTest.t (Wstat: 65280 Tests: 0 Failed: 0)
ntscalarTest.t (Wstat: 65280 Tests: 0 Failed: 0)
ntscalarArrayTest.t (Wstat: 65280 Tests: 0 Failed: 0)
ntnameValueTest.t (Wstat: 65280 Tests: 0 Failed: 0)
ntmultiChannelTest.t (Wstat: 65280 Tests: 0 Failed: 0)
ntscalarMultiChannelTest.t (Wstat: 65280 Tests: 0 Failed: 0)
nttableTest.t (Wstat: 65280 Tests: 0 Failed: 0)
ntndarrayTest.t (Wstat: 65280 Tests: 0 Failed: 0)
ntmatrixTest.t (Wstat: 65280 Tests: 0 Failed: 0)
ntenumTest.t (Wstat: 65280 Tests: 0 Failed: 0)
ntunionTest.t (Wstat: 65280 Tests: 0 Failed: 0)
ntaggregateTest.t (Wstat: 65280 Tests: 0 Failed: 0)
ntattributeTest.t (Wstat: 65280 Tests: 0 Failed: 0)
ntndarrayAttributeTest.t (Wstat: 65280 Tests: 0 Failed: 0)
ntcontinuumTest.t (Wstat: 65280 Tests: 0 Failed: 0)
nthistogramTest.t (Wstat: 65280 Tests: 0 Failed: 0)
Files=17, Tests=10, 24 wallclock secs ( 0.08 usr + 0.03 sys = 0.11 CPU)
Result: FAIL
Failed 16/17 test programs. 0/10 subtests failed.
testPVCopy.t ......... Can't spawn "./testPVCopy.exe": No error at testPVCopy.t line 12.
testPVCopy.t ......... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
testPVRecord.t ....... ok
testExampleRecord.t .. ok
testLocalProvider.t .. Can't spawn "./testLocalProvider.exe": No error at testLocalProvider.t line 12.
Can't run testLocalProvider.exe:
testLocalProvider.t .. Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
testPVAServer.t ...... Can't spawn "./testPVAServer.exe": No error at testPVAServer.t line 12.
Can't run testPVAServer.exe:
testPVAServer.t ...... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
Test Summary Report
testLocalProvider.t (Wstat: 65280 Tests: 0 Failed: 0)
testPVAServer.t (Wstat: 65280 Tests: 0 Failed: 0)
Files=5, Tests=10, 5 wallclock secs ( 0.06 usr + 0.00 sys = 0.06 CPU)
Result: FAIL
Failed 3/5 test programs. 0/10 subtests failed.
testmon.t .. Can't spawn "./testmon.exe": No error at testmon.t line 12.
Can't run testmon.exe:
testmon.t .. Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
Test Summary Report
testmon.t (Wstat: 65280 Tests: 0 Failed: 0)
Files=1, Tests=0, 2 wallclock secs ( 0.02 usr + 0.00 sys = 0.02 CPU)
Result: FAIL
Failed 1/1 test programs. 0/0 subtests failed.
testweak.t .. Can't spawn "./testweak.exe": No error at testweak.t line 12.
Can't run testweak.exe:
testweak.t .. Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
testtest.t .. Can't spawn "./testtest.exe": No error at testtest.t line 12.
Can't run testtest.exe:
testtest.t .. Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
testpvif.t .. Can't spawn "./testpvif.exe": No error at testpvif.t line 12.
Can't run testpvif.exe:
testpvif.t .. Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
testpdb.t ... Can't spawn "./testpdb.exe": No error at testpdb.t line 12.
Can't run testpdb.exe:
testpdb.t ... Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
Test Summary Report
testweak.t (Wstat: 65280 Tests: 0 Failed: 0)
testtest.t (Wstat: 65280 Tests: 0 Failed: 0)
testpvif.t (Wstat: 65280 Tests: 0 Failed: 0)
testpdb.t (Wstat: 65280 Tests: 0 Failed: 0)
Files=4, Tests=0, 4 wallclock secs ( 0.02 usr + 0.01 sys = 0.03 CPU)
Result: FAIL
Failed 4/4 test programs. 0/0 subtests failed.
H:\epics-devel\base-7.0.1>set EPICS_HOST_ARCH
I'm puzzled because I would have thought that this configuration was one that was tested on the Jenkins build server at the APS?
