See <http://gfa-sls2-test:8080/job/EPICS-3.16/24/display/redirect>
Started by timer
Building in workspace <http://gfa-sls2-test:8080/job/EPICS-3.16/ws/>
[WS-CLEANUP] Deleting project workspace...
[WS-CLEANUP] Done
Cloning the remote Git repository
Cloning repository https://git.launchpad.net/epics-base
> git init <http://gfa-sls2-test:8080/job/EPICS-3.16/ws/> # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
> git --version # timeout=10
> git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*
ERROR: Error cloning remote repo 'origin'
hudson.plugins.git.GitException: Command "git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*" returned status code 128:
stdout:
stderr: fatal: unable to access 'https://git.launchpad.net/epics-base/': The requested URL returned error: 503
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1970)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:1689)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$300(CliGitAPIImpl.java:71)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:380)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$2.execute(CliGitAPIImpl.java:589)
at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1083)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1123)
at hudson.scm.SCM.checkout(SCM.java:495)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1212)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:566)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:491)
at hudson.model.Run.execute(Run.java:1737)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:421)
- Jenkins build is back to normal : EPICS-3.16 #25 PSI Jenkins
Build failed in Jenkins: EPICS-3.14 #26 PSI Jenkins
Jenkins build is back to normal : EPICS-3.14 #27 PSI Jenkins
<2017>
<2017>
