Hi Torsten,
The four classic EPICS branches *are* branches of the very same single Git repository. The .gitmodules file specifies the current directory as the URL for the branches libcom, database and ca. However, the standard recursive git clone command interprets the local "." URL as "fetch it from the same place as the repo in '.'". You can always clone the classic branches one by one from the existing local repo of the bundle. Note, however, that pushes in the locally cloned branches will then go to the local origin, not the remote upstream repo, which is certainly confusing and not what users expect from a push operation. Independent from the submodules question,you can always reduce the amount of data in a clone by specifying --depth, unless you need the full history of the project, in this case spanning the last 25 years. Cheers, ~Ralph On Thu, Dec 14, 2017 at 9:20 AM, Torsten Bögershausen <[email protected]> wrote: Hej,
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
