Hi Andrew,
Thanks for the info.
I noticed that hex numbers are not possible in 3.16.1 and 3.15.5 when
running the 32bit mbbi/mbboDirect tests, where I used a hex number in DOL.
Dirk
On 13.12.2017 17:43, Andrew Johnson wrote:
Hi Dirk,
On 12/13/2017 07:00 AM, Dirk Zimoch wrote:
I noticed that I can use hex numbers in DOL with EPICS 7 but not with
3.16.1, 3.15.5 or earlier.
What about adding this option to 3.15/3.16?
Code to allow the use of hex numbers in CONSTANT links was committed to
the Base-3.15 branch in June:
commit 9d4a90ac34cc6decc0e12837b5bab45586e8c518
Author: Andrew Johnson <[email protected]>
Date: Thu Jun 22 14:29:04 2017 -0500
Fix link initialization from hex constants
Fixes LP: #1699445
Includes regression tests (some of which will fail on 3.16)
This was fixing a regression, my restructuring of the constant link code
(which was a necessary part of the link support development) changed the
string to integer conversions from using a mixture of strtol(),
strtoul() and sscanf() with %i or %u formats. The regression first
appeared in 3.14.12.3 and 3.15.0.1, and the above commit will fix it for
the 3.15.6 and 3.16.2 releases which we'll probably put out early in 2018.
- Andrew
- converting strings to integer Dirk Zimoch
- Re: converting strings to integer Andrew Johnson
Re: 7.0.1-rc1 Torsten Bögershausen
<2017>
makeBaseApp example / QSRV Ralph Lange
<2017>
