Hi Michael,
I have tested that fix on VS2015 and VS2017. It fixes the problem. I am now building all of R7.0.1-rc1 with that patch on 2010, 2015, and 2017.
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Michael Davidsaver
> Sent: Friday, December 08, 2017 2:32 PM
> To: Andrew Johnson; [email protected]
> Subject: Re: moving initHooks into libCom
> On 12/08/2017 03:29 PM, Andrew Johnson wrote:
> > Michael,
> > In case your Inbox filters out Jenkins emails the epics-master-windows
> > APS job is now demonstrating the pva2pva build failure.
> I noticed. If this is the only failure, then I might have it sorted out quickly.
> https://github.com/mdavidsaver/pva2pva/commit/049ed8cead5e59dea7f6631698c45ea63db
> 78d66
> > Thanks,
> > - Andrew
> > On 12/08/2017 02:09 PM, Andrew Johnson wrote:
> >> On 12/08/2017 01:57 PM, Mark Rivers wrote:
> >>> I forget exactly what CALL does, but I don't think it's necessary. It's
> >>> worth trying I guess.
> >> Yes, that fixed it. Jenkins runs build commands inside its own .BAT
> >> file, and apparently executing one .BAT file inside another stops the
> >> parent script. It's currently compiling using
> >>> Microsoft (R) C/C++ Optimizing Compiler Version 19.00.24215.1 for x64
> >> as against
> >>> Microsoft (R) C/C++ Optimizing Compiler Version 16.00.40219.01 for x64
> >>> Can you try the command interactively on that machine?
> >> I can't open a command window with the Jenkins build environment, the
> >> Jenkins agent sets up the shell environment by itself, and it's
> >> complicated by the fact that it's all running inside a JVM too.
> >> - Andrew
- Re: moving initHooks into libCom Andrew Johnson
- moving initHooks into libCom Michael Davidsaver
- Re: moving initHooks into libCom Michael Davidsaver
- RE: moving initHooks into libCom Mark Rivers
<2017>
<2017>
