2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: moving initHooks into libCom
To: Andrew Johnson <[email protected]>, [email protected]
Date: Fri, 8 Dec 2017 15:31:40 -0500
On 12/08/2017 03:29 PM, Andrew Johnson wrote:
> Michael,
> In case your Inbox filters out Jenkins emails the epics-master-windows
> APS job is now demonstrating the pva2pva build failure.
I noticed.  If this is the only failure, then I might have it sorted out quickly.
https://github.com/mdavidsaver/pva2pva/commit/049ed8cead5e59dea7f6631698c45ea63db78d66
> Thanks,
> - Andrew
> On 12/08/2017 02:09 PM, Andrew Johnson wrote:
>> On 12/08/2017 01:57 PM, Mark Rivers wrote:
>>> I forget exactly what CALL does, but I don't think it's necessary.  It's
>>> worth trying I guess.
>> Yes, that fixed it. Jenkins runs build commands inside its own .BAT
>> file, and apparently executing one .BAT file inside another stops the
>> parent script. It's currently compiling using
>>> Microsoft (R) C/C++ Optimizing Compiler Version 19.00.24215.1 for x64
>> as against
>>> Microsoft (R) C/C++ Optimizing Compiler Version 16.00.40219.01 for x64
>>> Can you try the command interactively on that machine?
>> I can't open a command window with the Jenkins build environment, the
>> Jenkins agent sets up the shell environment by itself, and it's
>> complicated by the fact that it's all running inside a JVM too.
>> - Andrew
Re: moving initHooks into libCom Ralph Lange
RE: moving initHooks into libCom Mark Rivers
moving initHooks into libCom Michael Davidsaver
Re: moving initHooks into libCom Andrew Johnson
Re: moving initHooks into libCom Michael Davidsaver
Prev: Re: moving initHooks into libCom Andrew Johnson
Next: Re: moving initHooks into libCom Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
