2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: Build failed in Jenkins: epics-master-windows » DLL,win64 #22
To: 'Andrew Johnson' <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 8 Dec 2017 20:24:20 +0000
OK, you are running Visual Studio 2015.  It is failing with the same error as seen in 2013 and 2017.
So Michael should be able to use the Jenkins server to fix the problem.
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Andrew Johnson
> Sent: Friday, December 08, 2017 2:20 PM
> To: [email protected]
> Subject: Re: Build failed in Jenkins: epics-master-windows » DLL,win64 #22
> Ok, to find the actually compiler error search for "Error C" in the full
> build log, it doesn't appear in the email.
> - Andrew
> On 12/08/2017 02:13 PM, APS Jenkins wrote:
> > See <https://jenkins.aps.anl.gov/job/epics-master-
> windows/LIBRARIES=DLL,OS=win64/22/display/redirect>
> Arguing for surveillance because you have nothing to hide is no
> different than making the claim, "I don't care about freedom of
> speech because I have nothing to say." -- Edward Snowdon
Build failed in Jenkins: epics-master-windows » DLL,win64 #22 APS Jenkins
Re: Build failed in Jenkins: epics-master-windows » DLL,win64 #22 Andrew Johnson
Prev: Re: Build failed in Jenkins: epics-master-windows » DLL,win64 #22 Andrew Johnson
Next: Build failed in Jenkins: epics-master-windows » STATIC,win32 #22 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: Build failed in Jenkins: epics-master-windows » DLL,win32 #22 APS Jenkins
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
