On 07.12.2017 17:42, Dirk Zimoch wrote:
I tried to do changes on modules/database
When I wanted to commit, I get the error that I am not on any branch.
Then I did
* git stash
* in the top level: git submodule update --remote
* back in modules/database: git co core/master
* git stash apply
Here I get the errors:
CONFLICT (delete/modify): src/std/dev/devMbbiDirectSoft.c deleted in
Updated upstream and modified in Stashed changes. Version Stashed
changes of src/std/dev/devMbbiDirectSoft.c left in tree.
... [for all my changes]
git status tells me:
# On branch core/master
# Unmerged paths:
# (use "git reset HEAD <file>..." to unstage)
# (use "git add/rm <file>..." as appropriate to mark resolution)
# deleted by us: ../../../src/std/dev/devMbbiDirectSoft.c
# deleted by us:
../../../src/std/dev/devMbbiDirectSoftCallback.c
# deleted by us: ../../../src/std/dev/devMbbiDirectSoftRaw.c
# deleted by us: ../../../src/std/dev/devMbboDirectSoft.c
# deleted by us:
../../../src/std/dev/devMbboDirectSoftCallback.c
# deleted by us: ../../../src/std/rec/mbbiDirectRecord.c
# deleted by us: ../../../src/std/rec/mbbiDirectRecord.dbd
# deleted by us: ../../../src/std/rec/mbboDirectRecord.c
# deleted by us: ../../../src/std/rec/mbboDirectRecord.dbd
# deleted by us: Makefile
My changes are seemingly gone (?) and the module is distressingly empty.
Wrong branch? Maybe.
---WRONG DIRECTORY
git co database/master
error: Your local changes to the following files would be overwritten by
checkout:
configure/os/CONFIG_SITE.Common.vxWorksCommon
configure/os/CONFIG_SITE.linux-x86.Common
configure/os/CONFIG_SITE.linux-x86_64.Common
Please, commit your changes or stash them before you can switch branches.
Aborting
src/std/dev/devMbbiDirectSoft.c: needs merge
src/std/dev/devMbbiDirectSoftCallback.c: needs merge
src/std/dev/devMbbiDirectSoftRaw.c: needs merge
src/std/dev/devMbboDirectSoft.c: needs merge
src/std/dev/devMbboDirectSoftCallback.c: needs merge
src/std/rec/mbbiDirectRecord.c: needs merge
src/std/rec/mbbiDirectRecord.dbd: needs merge
src/std/rec/mbboDirectRecord.c: needs merge
src/std/rec/mbboDirectRecord.dbd: needs merge
test/std/rec/Makefile: needs merge
error: you need to resolve your current index first
Still: HELP!
HELP!
- more git problems Dirk Zimoch
Re: more git problems Michael Davidsaver
<2017>
<2017>
