2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: base-7.0, can't make on linux
To: EPICS core-talk <[email protected]>
Date: Thu, 7 Dec 2017 17:26:47 +0100
I checked out the base-7.0:
git clone --recursive -b core/master https://git.launchpad.net/epics-base base-7.0
running “make” gives:
make -C ./libcom install
make[2]: Entering directory '/home/fel/EPICS/base-7.0/modules/libcom'
configure/CONFIG:19: /configure/CONFIG: No such file or directory
configure/RULES_TOP:2: /configure/RULES_TOP: No such file or directory
make[2]: *** No rule to make target '/configure/RULES_TOP'.  Stop.
make[2]: Leaving directory '/home/fel/EPICS/base-7.0/modules/libcom'
../configure/RULES_DIRS:84: recipe for target 'libcom.install' failed
make[1]: *** [libcom.install] Error 2
make[1]: Leaving directory '/home/fel/EPICS/base-7.0/modules'
configure/RULES_DIRS:84: recipe for target 'modules.install' failed
make: *** [modules.install] Error 2
With the tar-file
https://www.aps.anl.gov/epics/download/base/base-7.0.1-rc1.tar.gz
everything works well.
Heinz
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: base-7.0, can't make on linux Andrew Johnson
RE: base-7.0, can't make on linux Mark Rivers
Prev: Question about EPICS 7 unit tests Dirk Zimoch
Next: Re: base-7.0, can't make on linux Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: Question about EPICS 7 unit tests Andrew Johnson
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
