2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: Link problem in areaDetector with pva libraries
To: 'Andrew Johnson' <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 5 Dec 2017 21:37:38 +0000
I added pvAccessIOC to commonDriverMakefile and that fixed the link problem.
However, since that is a new library, how can I have my Makefile only link that library if I am building with EPICS 7 and not link it with EPICS4-CPP-4.6.0?
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Andrew Johnson
> Sent: Tuesday, December 05, 2017 3:14 PM
> To: [email protected]
> Subject: Re: Link problem in areaDetector with pva libraries
> Hi Mark,
> On 12/05/2017 02:28 PM, Mark Rivers wrote:
> > Thanks to a suggestion from Bruno ADCore now compiles OK.
> Great.
> > I now have a problem when linking the IOC applications:
> > -lsimDetector -lNDPlugin -lADBase -lntndArrayConverter -lnt -lpvDatabase
> > -lpvAccess -lpvData
> > -lnetCDF -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp
> > -llcms -lttf -lwmf
> > -lfilters -ltiff -ljpeg -lxml2 -lNeXus -lhdf5 -lblosc -lszip -lzlib
> > -lasyn -lautosave -lbusy -lcalc
> > -ldevIocStats -lsscan -lseq -lpv -ldbRecStd -ldbCore -lca -lCom
> > -Wl,-Bdynamic -lX11 -lXext -lpthread
> > -lreadline -lm -lrt -ldl -lgcc
> > undefined reference to `pvar_func_refTrackRegistrar'
> > undefined reference to `pvar_func_registerStartPVAServer'
> > Is this a problem with the order of link libraries?
> I believe those particular routines are found in libpvAccessIOC which I
> don't see in your link line at all. That's a new library in this
> release, as is libpvAccessCA although you might not need that.
> > When using EPICS 7 does one still need to link explicitly with pvAccess,
> > pvDatabase, etc. or are those included in EPICS_BASE_IOC_LIBS or some
> > other symbol?
> We provide a new variable EPICS_BASE_PVA_CORE_LIBS which contains the
> core PVA libraries (put this in your *_LIBS before EPICS_BASE_IOC_LIBS):
> > EPICS_BASE_PVA_CORE_LIBS = pvAccessIOC pvAccessCA pvAccess pvData
> Note that neither nt nor pvDatabase are included there, they still need
> to appear before the above variable. If you want the IOC to be able to
> serve records over pvAccess and your DBD file includes qsrv.dbd you will
> also need the qsrv library, also before either of the variables.
> HTH,
> - Andrew
> Arguing for surveillance because you have nothing to hide is no
> different than making the claim, "I don't care about freedom of
> speech because I have nothing to say." -- Edward Snowdon
Re: Link problem in areaDetector with pva libraries Andrew Johnson
Link problem in areaDetector with pva libraries Mark Rivers
Prev: Re: Link problem in areaDetector with pva libraries Andrew Johnson
Next: Re: Link problem in areaDetector with pva libraries Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
