2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: EPICS 7 Release Candidate 1
To: 'Andrew Johnson' <[email protected]>, 'Michael Davidsaver' <[email protected]>, "'[email protected]'" <[email protected]>
Date: Mon, 4 Dec 2017 18:17:12 +0000
> I like to work with a git checkout because it is then easy to find all my local changes, look at
> file history, etc.  If I were to work from Launchpad as Ralph suggested then would I need
> to learn how to use bazaar?
I just answered my own question.  I was able to do a git checkout from Launchpad.
git clone --recursive https://git.launchpad.net/epics-base
I found that it was very slow.  It was averaging about 200 KiB/s, which is 20 times slower than the 4 MiB/s I got with Github.  Is this normal?
I am still struggling to understand how to checkout the R7.0.1-rc1 tag in the top-level and all submodules.  I did what Michael suggested:
corvette:~/scratch/epics-base>git submodule update
corvette:~/scratch/epics-base>git reset --hard R7.0.1-rc1
HEAD is now at 8b97e78 Set version snapshot to -rc1
However, when I go into the modules/ca it is in a different detached HEAD state:
corvette:~/scratch/epics-base>cd modules/ca
/home/epics/scratch/epics-base/modules/ca
corvette:epics-base/modules/ca>git status
# HEAD detached at 5dfd1fc
nothing to commit, working directory clean
corvette:epics-base/modules/ca>git diff --name-status R7.0.1-rc1
D       .appveyor.yml
D       .ci/appveyor-make.bat
D       .ci/appveyor-prepare.bat
D       .ci/checkout-modules.sh
D       .ci/make-tar.sh
M       .ci/travis-build.sh
M       .ci/travis-prepare.sh
D       .gitattributes
M       .gitignore
D       .gitmodules
M       .travis.yml
M       Makefile
D       README
So it does not appear to have the R7.0.1-rc1 tag checked out?
I then try to explicitly checkout that tag in all submodules, but it fails because that tag does not exist in modules/normativeTypes:
corvette:~/scratch/epics-base>git submodule foreach git checkout R7.0.1-rc1
Entering 'modules/ca'
Previous HEAD position was 5dfd1fc... Export tool configurations as cfg/CONFIG_* files
HEAD is now at 8b97e78... Set version snapshot to -rc1
Entering 'modules/database'
Previous HEAD position was eac8865... Merge 'ignore-siml-failure' into database/master
Entering 'modules/libcom'
Previous HEAD position was 3ca5c20... perl 5.8 compatibility fix
Entering 'modules/normativeTypes'
error: pathspec 'R7.0.1-rc1' did not match any file(s) known to git.
Stopping at 'modules/normativeTypes'; script returned non-zero status.
But if I go to modules/ca it is indeed checked out that the tag I want.
# HEAD detached at R7.0.1-rc1
> -----Original Message-----
> From: Mark Rivers
> Sent: Monday, December 04, 2017 11:09 AM
> To: 'Andrew Johnson'; Michael Davidsaver; [email protected]
> Hi Andrew,
> > I just added the correct git clone command to the R7-0/1.php page (it was already on the
> R7-0/index.php page).
> Thanks for that.  Those instructions say:
> To checkout the latest source code using git use the git command below, which will include
> some additional files not in the tarfile. Note that the development branch for EPICS 7 is
> called core/master, and some of the submodules are fetched from Launchpad while others
> are on Github:
> git clone --recursive -b core/master https://git.launchpad.net/epics-base base-7.0
> Suppose I do that, but then I don't want to work on the master branch, but rather to work
> on the R7.01.-rc1 tag.  Can I do that now, or do I need to wait until those tags propagate to
> Github?
> Any idea why a git clone using ssh ([email protected]:epics-base/epics/base) does not work,
> while it works fine for areaDetector/areaDetector?  Is this a permissions problem?
> Thanks,
> Mark
> > From: Andrew Johnson [mailto:[email protected]]
> > Sent: Monday, December 04, 2017 10:47 AM
> > To: Mark Rivers; Michael Davidsaver; [email protected]
> > Subject: Re: EPICS 7 Release Candidate 1
> > Hi Mark,
> > On 12/03/2017 08:21 PM, Mark Rivers wrote:
> > > After doing
> > > git reset --hard R7.0.1-pre1
> > > then it built fine.
> > Note that the top-level branch that you need to check out to get the
> > development version is called core/master. Branch names for the
> > submodules are somewhat variable, but 'git submodule update --remote'
> > will update them all to their latest commits.
> > was already on the R7-0/index.php page).
> > - Andrew
> > Arguing for surveillance because you have nothing to hide is no
> > different than making the claim, "I don't care about freedom of
> > speech because I have nothing to say." -- Edward Snowdon
Re: EPICS 7 Release Candidate 1 Andrew Johnson
Re: EPICS 7 Release Candidate 1 Mark Rivers
Re: EPICS 7 Release Candidate 1 Michael Davidsaver
RE: EPICS 7 Release Candidate 1 Mark Rivers
Prev: RE: EPICS 7 Release Candidate 1 Mark Rivers
Next: Re: EPICS 7 Release Candidate 1 Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
