On 30.11.2017 13:33, Dirk Zimoch wrote:
On 29.11.2017 20:51, Michael Davidsaver wrote:
On 11/29/2017 12:43 PM, Dirk Zimoch wrote:
The file anyscalar.h generates many warnings of the form
/afs/psi.ch/group/8431/dirk/git/BASE/epics-base-master/include/pv/anyscalar.h:98:
warning: dereferencing pointer ‘<anonymous>’ does break
strict-aliasing rules
The construct used (std::aligned_storage) is well defined in c++11.
http://en.cppreference.com/w/cpp/types/aligned_storage
I am a bit concerned about that because it may lead to wrong
optimization. I think this should either be fixed or
-fno-strict-aliasing should be added to the compiler flags for recent
gccs (i.e. not old vxWorks :-) )
GCC >=4.8.4 (at latest) doesn't warn about this even with -std=c++98.
So if anything, this is only need for older compilers.
I checked the code and found that older compilers (those who complain)
see a different piece of code. (#if __cplusplus>=201103L ... #else). And
not all of them complain.
I will do some tests to find out if I can remove the warnings. If not, I
will add the -fno-strict-aliasing compiler option to my architectures
which use older compilers and to the vxWorks configuration in EPICS.
But this is no showstopper for the release.
No warnings using std::aligned_storage
Yocto 2.1 (gcc 6.2.1)
No warnings using union blob_t
RHEL 7.3 (gcc 4.8.5)
RHEL 7.3 (clang 3.4.2)
SL6 (clang 3.4.2)
vxWorks 6.7 (gcc 4.1.2)
vxWorks 6.6 (gcc 4.1.2)
vxWorks 6.3 (gcc 3.4.4)
ELDK 4.2 (gcc 4.2.2)
ELDK 5.1 (gcc 4.6.1)
ELDK 5.2(gcc 4.6.4)
FSL 2.0 (gcc 4.9.2)
Warnings using union blob_t
SL6 (gcc 4.4.7)
moxa42-armv6l (gcc 4.4.2)
So the warnings seem to be limited to gcc 4.4.
For those architectures I have now set:
ARCH_DEP_CXXFLAGS += -fno-strict-aliasing
BTW: I have along weekend now. Back on Tuesday.
Dirk
- warnings about strict aliasing Dirk Zimoch
- Re: warnings about strict aliasing Michael Davidsaver
- Re: warnings about strict aliasing Dirk Zimoch
<2017>
<2017>
