Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: SIML type CA and PINI=YES issue
To: <core-talk@aps.anl.gov>
Date: Wed, 29 Nov 2017 15:01:05 -0600
On 11/29/2017 02:44 PM, Ralph Lange wrote:
>     This is one of those situations when a link type that atomically reads a
>     dbState value might be worthwhile, and a better solution than using CA
>     links. Actually why limit ourselves to just binary values, why not
>     create a link type that provides atomic access to any shared storage
>     (similar to the old global symbol support, but with proper thread
>     protection)?
> We have a single simulation switch bo record per PLC, and it resides on
> the IOC connecting to the PLC.
> We only need CA links in SIML to not have all >10K records be in a
> single lock set.
Right, and by setting all your SIML inputs to read the same dbState
value they can read the binary value from the state without all the
added complexity of a CA link.
    field(SIML, {state:simMode})
You would also have a bo record to set the simMode dbState value.
Next release maybe...
> I will prepare a merge proposal tomorrow.
Okay.
- Andrew
SIML type CA and PINI=YES issue Ralph Lange
Re: SIML type CA and PINI=YES issue Ralph Lange
Re: SIML type CA and PINI=YES issue Kasemir, Kay
Re: SIML type CA and PINI=YES issue Andrew Johnson
Prev: RE: EPICS 7.0.1-pre1 -- vxWorks 6.2 Mark Rivers
Next: RE: EPICS 7.0.1-pre1 -- vxWorks 6.2 Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Re: SIML type CA and PINI=YES issue Ralph Lange
Next: warnings about strict aliasing Dirk Zimoch
ANJ, 29 Nov 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
