2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS 7.0.1-pre1 -- vxWorks 6.2
To: <[email protected]>
Date: Wed, 29 Nov 2017 13:47:40 -0600
On 11/29/2017 02:07 AM, Dirk Zimoch wrote:
> I will try to implement something. My first attempt failed for the
> reason Andrew outlined. It is not possible to simply skip the all PVA
> modules for a specific T_A because at that time T_A is not yet defined.
> A flag needs to be checked inside every module.
It's even more complicated than that though; once we get Base to only
build the PVA modules for some target architectures and not for others,
how are the Makefiles in downstream modules such as AreaDetector
supposed to be set up to only build things that depend on PVA for
targets that have PVA built?
After thinking this over last night I now think it would be much more
complex and invasive than the original idea appears. It certainly isn't
going to be possible in the 7.0.1 release.
If you want to use EPICS 7, I think you will have to upgrade your
devices to run on a fully supported OS; partial support like this is
likely to be too invasive to be cost-effective.
- Andrew
Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Ralph Lange
RE: EPICS 7.0.1-pre1 -- vxWorks 6.2 Mark Rivers
EPICS 7.0.1-pre1 Andrew Johnson
Re: EPICS 7.0.1-pre1 Dirk Zimoch
Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Dirk Zimoch
Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Hartman, Steven M.
Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Timo Korhonen
Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Andrew Johnson
Prev: Re: SIML type CA and PINI=YES issue Kasemir, Kay
Next: EPICS 7 vxWorks diff Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Dirk Zimoch
Next: Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Ralph Lange
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
