2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS 7.0.1-pre1 -- vxWorks 6.2
To: <[email protected]>
Date: Tue, 28 Nov 2017 18:05:41 -0600
Hi Timo,
On 11/28/2017 10:46 AM, Timo Korhonen wrote:
> Referring to Dirk's request earlier in this chain:
> So it would be nice to have an option in one of the CONFIG files to
> declare that a specific architecture should build EPICS 7 without PVA
> support.
> If I understand the intention right, he would like to be able to build the
> EPICS 7 base for many architectures but so that not all of them are
> required to support PVA.
> I think that is a legitimate request: this way he can keep up with the
> other updates in the base and does not have to abandon (at least
> immediately) those architectures that are not able to support PVA.
> I think this could make the adoption of EPICS 7 easier not only for Dirk
> but for other sites, too. The change does not look impossible to me.
I agree that this is worthwhile goal, but I'm not sure how easy it will
be to implement at this stage. The complication is that GNUmake descends
through the tree just once, and it's not until it gets to the bottom
Makefiles that it decides which target architectures to compile the code
for. I don't want to have to edit every Makefile and put a conditional
test in them, but I might be able to do something in the modules' own
configure/CONFIG files.
I can't promise anything for the -rc1, but I will try to implement
something for the final release if I can do so cleanly.
- Andrew
Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Dirk Zimoch
Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Timo Korhonen
EPICS 7.0.1-pre1 Andrew Johnson
Re: EPICS 7.0.1-pre1 Dirk Zimoch
Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Hartman, Steven M.
Prev: Re: EPICS 7.0.1-pre1 (epicsException.h) Michael Davidsaver
Next: Re: git question Torsten Bögershausen
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Timo Korhonen
Next: Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Dirk Zimoch
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
