On 11/28/2017 12:45 PM, Andrew Johnson wrote:
>> diff --git a/src/client/pva/client.h b/src/client/pva/client.h
>> index 08998b3..7721adb 100644
>> --- a/src/client/pva/client.h
>> +++ b/src/client/pva/client.h
>> @@ -193,7 +193,11 @@ void registerRefTrack();
>> class epicsShareClass ClientChannel
>> +#if defined __GNUC__ && __GNUC__*100+__GNUC_MINOR__ < 305
>> +public:
>> +#endif
>> struct Impl;
>> +private:
>> std::tr1::shared_ptr<Impl> impl;
>> friend class ClientProvider;
>> friend void detail::registerRefTrack();
> That looks a little strange, but could be a valid workaround to a gcc issue.
It is a workaround, and I can't think of a better one. The issue is that the
"friend class ClientProvider;" should apply to "ClientProvider::Impl" as well.
Apparently this isn't the case for gcc 3.5.
Exposing this type isn't a practical issue as there isn't much which can be done with it.
The definition is hidden and the methods which use it remain private.
>> I was expecting a change like this to pvif (in class FieldName), so
>> I'm not clear what's going on here.
> I don't see anything comparable in pvif.h.
It's the situation where
> void method(const FieldName&);
> method(Fieldname())
required an accessible copy ctor in older iterations of the c++ standard,
although I hope it would never actually be called.
- EPICS 7.0.1-pre1 Andrew Johnson
- Re: EPICS 7.0.1-pre1 Dirk Zimoch
- Re: EPICS 7.0.1-pre1 (epicsException.h) Dirk Zimoch
- Re: EPICS 7.0.1-pre1 (epicsException.h) Andrew Johnson
- Re: EPICS 7.0.1-pre1 (epicsException.h) Michael Davidsaver
Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Andrew Johnson
<2017>
<2017>
