2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS 7.0.1-pre1 (epicsException.h)
To: Andrew Johnson <[email protected]>, [email protected]
Date: Tue, 28 Nov 2017 14:46:02 -0600
On 11/28/2017 12:45 PM, Andrew Johnson wrote:
>> I don't like removing FORCE_INLINE from castUnsafe().  This needs
>> further analysis and a more target fix.
>> https://gcc.gnu.org/bugzilla/show_bug.cgi?id=54965
> Awaiting your suggestions there then.
My thought is to replace the jump table with nested switch().
So far this is just in my repo.
I guess we would have to wait for Dirk to find out if this actually fixes
the problem he sees.
I had a look and this change does result in slightly shorter code,
presumably because the gcc optimizer has an easier time dealing with switch().
So this change may be work including on its own merits.
https://github.com/mdavidsaver/pvDataCPP/commit/156e7563dbcaf585e704ead631b0902fef12fdb2
EPICS 7.0.1-pre1 Andrew Johnson
Re: EPICS 7.0.1-pre1 Dirk Zimoch
Re: EPICS 7.0.1-pre1 (epicsException.h) Dirk Zimoch
Re: EPICS 7.0.1-pre1 (epicsException.h) Andrew Johnson
Re: EPICS 7.0.1-pre1 (epicsException.h) Michael Davidsaver
Prev: Re: EPICS 7.0.1-pre1 (epicsException.h) Andrew Johnson
Next: Re: EPICS 7.0.1-pre1 (epicsException.h) Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS 7.0.1-pre1 (epicsException.h) Dirk Zimoch
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
