I think the attached patch file solves it.
On 28.11.2017 17:53, Dirk Zimoch wrote:
I am trying to get it done right now.
But unfortunately after updating core/master, it does not compile any
more for my host architecture.
And the day end in 7 minutes.
I probably send you a patch file instead of what I thinks should work.
On 28.11.2017 17:49, Andrew Johnson wrote:
Hi Dirk,
Michael and I need to know exactly what changes you still need to be
committed for the VxWorks 6.3 and/or 6.7 builds that are not already in
our repositories. Posting the output from 'git diff' rather than just a
description like this is much better, it ensures we don't miss anything.
If you can do that TODAY we'd appreciate it, we're wanting to tag the
-rc1 release, and we'd prefer to have your changes included if possible.
- Andrew
On 11/28/2017 09:39 AM, Dirk Zimoch wrote:
The __GNUC__ version of the macro SHOW_EXCEPTION from
modules/pvData/src/misc/pv/epicsException.h crashes g++ version 3.4.4
/afs/psi.ch/project/vxworks/WindRiverGPP3.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/../lib/gcc/powerpc-wrs-vxworks/3.4.4/../../../../include/c++/3.4.4/xstring:
In function `void testLogicException()':
/afs/psi.ch/project/vxworks/WindRiverGPP3.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/../lib/gcc/powerpc-wrs-vxworks/3.4.4/../../../../include/c++/3.4.4/xstring:78:
internal compiler error: in expand_expr_real, at expr.c:8417
Please submit a full bug report,
with preprocessed source if appropriate.
Contact [email protected] for instructions.
This can be fixed by using the non-__GNUC__ version for __GNUC__ < 4
#if !defined __GNUC__ || __GNUC__ < 4
# define SHOW_EXCEPTION(EI) ::epics::pvData::detail::showException(EI)
With that change, I could finally build EPICS 7 for vxWorks 6.3.
(Thus the boost header spinlock_pt.hpp is not obsolete.)
diff -x 'O.*' -x '.*' -r ../base-7.0.1-pre1/modules/pvAccess/src/client/pv/pvAccess.h ./modules/pvAccess/src/client/pv/pvAccess.h
1447d1446
< virtual ~ChannelProviderRegistry() {}
diff -x 'O.*' -x '.*' -r ../base-7.0.1-pre1/modules/pvAccess/src/client/pva/client.h ./modules/pvAccess/src/client/pva/client.h
195,197d194
< #if defined __GNUC__ && __GNUC__*100+__GNUC_MINOR__ < 305
< public:
< #endif
199d195
< private:
diff -x 'O.*' -x '.*' -r ../base-7.0.1-pre1/modules/pvData/src/misc/pv/epicsException.h ./modules/pvData/src/misc/pv/epicsException.h
184c184
< #if !defined __GNUC__ || __GNUC__ < 4
> #ifndef __GNUC__
diff -x 'O.*' -x '.*' -r ../base-7.0.1-pre1/modules/pvData/src/misc/pv/reftrack.h ./modules/pvData/src/misc/pv/reftrack.h
113c113
< virtual ~RefMonitor();
> ~RefMonitor();
diff -x 'O.*' -x '.*' -r ../base-7.0.1-pre1/modules/pvData/src/misc/pv/typeCast.h ./modules/pvData/src/misc/pv/typeCast.h
168c168
< static inline TO castUnsafe(const FROM& from)
> static FORCE_INLINE TO castUnsafe(const FROM& from)
- Re: EPICS 7.0.1-pre1 (epicsException.h) Andrew Johnson
- EPICS 7.0.1-pre1 Andrew Johnson
- Re: EPICS 7.0.1-pre1 Dirk Zimoch
- Re: EPICS 7.0.1-pre1 (epicsException.h) Dirk Zimoch
<2017>
<2017>
