Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: EPICS 7 not handling configuration errors
To: "core-talk@aps.anl.gov" <core-talk@aps.anl.gov>
Date: Mon, 27 Nov 2017 16:01:42 +0100
EPICS 7 could be more verbose in case of configuration errors.
If I try this:
make CROSS_COMPILER_TARGET_ARCHS=doesnotexist
I do not get an error message complaining about missing configuration files for the "doesnotexist" architecture.
Instead I get:
make[4]: Entering directory `/afs/psi.ch/group/8431/dirk/git/BASE/base-7.0.1-pre1/modules/libcom/src/O.doesnotexist' perl -CSD ../../src/error/makeStatTbl.pl ../../src/osi/devLib.h ../../src/osi/epicsTime.h ../../src/as/asLib.h ../../src/misc/epicsStdlib.h ../../src/pool/epicsThreadPool.h ../../src/error/errMdef.h
perl -CSD ../../src/env/bldEnvData.pl  -t doesnotexist \
        -c gcc -s  /usr/local/epics/base-7.0.1/configure
Usage: bldEnvData.pl [options] configure
  -h       Help: Print this message
  -q       Quiet: Only print errors
  -o file  Output filename, default is envData.c
  -t arch  Target architecture $(T_A) name
  -s os    Operating system $(OS_CLASS)
  -c comp  Compiler class $(CMPLR_CLASS)
/usr/local/epics/base-7.0.1/bin/RHEL7-x86_64/e_flex -S/usr/local/epics/base-7.0.1/include/flex.skel.static -8 -I -t ../../src/as/asLib_lex.l > asLib_lex.yy.c
mv asLib_lex.yy.c asLib_lex.c
/usr/local/epics/base-7.0.1/bin/RHEL7-x86_64/antelope -basLib ../../src/as/asLib.y
mv asLib.tab.c asLib.c
make[4]: *** No rule to make target `../O.Common/osiFileName.h', needed by `inc'. Stop.
Took me a while to find out that the error was a missing config file.
EPICS is more helpful if the host architecture configuration is missing:
make EPICS_HOST_ARCH=nosuchhost
configure/CONFIG:54: configure/os/CONFIG.nosuchhost.Common: No such file or directory make: *** No rule to make target `configure/os/CONFIG.nosuchhost.Common'. Stop.
Not nice but points in the correct direction.
Dirk
Prev: Re: EPICS 7.0.1-pre1 Dirk Zimoch
Next: Re: EPICS 7.0.1-pre1 (spinlock.hpp) Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Re: EPICS 7 makeBaseApp Michael Davidsaver
Next: git question Dirk Zimoch
ANJ, 28 Nov 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
