Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: EPICS 7.0.1-pre1
To: EPICS core-talk <core-talk@aps.anl.gov>
Date: Sun, 26 Nov 2017 16:19:16 +0100
make runtests on OS-X (10.13.1 High Sierra) works well except at the very end:
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./pva2pva runtests
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./configure runtests
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C O.darwin-x86 -f ../Makefile TOP=../.. \
	    T_A=darwin-x86 runtests
perl -CSD -MTest::Harness -e 'runtests @ARGV if @ARGV;'
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./p2pApp runtests
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./pdbApp runtests
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./testApp runtests
perl -CSD -MTest::Harness -e 'runtests @ARGV if @ARGV;' testweak.t testtest.t testmon.t testpvif.t testpdb.t
testweak.t .. ok
testtest.t .. dyld: Library not loaded: /usr/local/opt/jsoncpp/lib/libjsoncpp.11.dylib
  Referenced from: /usr/local/lib/libtestutils.dylib
  Reason: image not found
testtest.t .. No subtests run
testmon.t ... dyld: Library not loaded: /usr/local/opt/jsoncpp/lib/libjsoncpp.11.dylib
testmon.t ... No subtests run
testpvif.t .. dyld: Library not loaded: /usr/local/opt/jsoncpp/lib/libjsoncpp.11.dylib
testpvif.t .. No subtests run
testpdb.t ... dyld: Library not loaded: /usr/local/opt/jsoncpp/lib/libjsoncpp.11.dylib
testpdb.t ... No subtests run
Test Summary Report
testtest.t (Wstat: 6 Tests: 0 Failed: 0)
  Non-zero wait status: 6
  Parse errors: No plan found in TAP output
testmon.t (Wstat: 6 Tests: 0 Failed: 0)
testpvif.t (Wstat: 6 Tests: 0 Failed: 0)
testpdb.t (Wstat: 6 Tests: 0 Failed: 0)
Files=5, Tests=37,  1 wallclock secs ( 0.03 usr  0.01 sys +  0.07 cusr  0.06 csys =  0.17 CPU)
Result: FAIL
Failed 4/5 test programs. 0/37 subtests failed.
make[4]: [runtests] Error 255 (ignored)
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./iocBoot runtests
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./ioccircle runtests
make[4]: Nothing to be done for `runtests'.
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./ioccircle2 runtests
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./iocimagedemo runtests
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./iocwfdemo runtests
Heinz
> downloaded from the EPICS website, at the usual locations:
>    http://www.aps.anl.gov/epics/base/R7-0/1.php
>    https://www.aps.anl.gov/epics/download/base/index.php
> The documentation listed on the R7-0/1 page is incomplete and still
> somewhat sparse, but it should be possible to download and build the
> software with no special knowledge beyond that needed to build Base-3.16.1.
> Note that the first release candidate (7.0.1-rc1) will be published
> significantly sooner than in the past, most likely next Tuesday (before
> the US Thanksgiving holiday next Thursday), and will be announced to the
> whole community on the tech-talk list. Until then please use core-talk
> for feedback and technical discussions.
> Many thanks to everyone who has contributed towards this release, which
> incorporates both EPICS Base (3.16 plus additional features) and the V4
> C++ modules (pvData, pvAccess, normative types, etc.).
> - Andrew
> Arguing for surveillance because you have nothing to hide is no
> different than making the claim, "I don't care about freedom of
> speech because I have nothing to say." -- Edward Snowdon
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: EPICS 7.0.1-pre1 Hartman, Steven M.
Re: EPICS 7.0.1-pre1 Michael Davidsaver
EPICS 7.0.1-pre1 Andrew Johnson
Prev: Re: EPICS 7 makeBaseApp Michael Davidsaver
Next: Re: EPICS 7.0.1-pre1 Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Re: EPICS 7.0.1-pre1 (epicsException.h) Dirk Zimoch
Next: Re: EPICS 7.0.1-pre1 Hartman, Steven M.
ANJ, 29 Nov 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
