2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS 7.0.1-pre1 (spinlock.hpp)
To: "Johnson, Andrew N." <[email protected]>
Date: Fri, 24 Nov 2017 08:33:23 +0100
Hi Andrew,
So far I needed only that one file. VxWorks 6.2 and 6.3 use gcc 3.3.2 and 3.4.4. They may not have __sync_lock_test_and_set().
Actually I do not use vxWorks 6.2 or 6.3 but 5.5. :-)
If switching to vxWorks 6 I will go for 6.7 or newer.
But since we have those versions for another project (not using EPICS), I thought it may be good to check for maximum compatibility.
As I get other errors now, vxWorks 6.3- compatibility may not be possible. I need to try more fixes.
I will set up a Jenkis server in the next few days. However I fear due to PSI networking regulations it will not be accessible from outside PSI. Is it OK to send the messages to core-talk?
Dirk
On 23.11.2017 19:23, Johnson, Andrew N. wrote:
Hi Dirk,
The complete Boost version used in Base-7.0.1-pre1 can be found in the
any version of the V4 dBCommonCPP application; the full source is huge
though so I only pulled the files into 7.0.1 that I knew were needed. If
you can keep track of and send me a list of all the additional Boost
files that you need I will add them before the -rc1 release.
If you want EPICS to support VxWorks versions before 6.8 you *do* need
to actively support it by doing builds , running tests and reporting
problems (preferably as early in the development process as possible).
APS doesn’t use or have either of these versions installed so we can’t
do that for you.
- Andrew
Sent from my iPad
On Nov 23, 2017, at 9:34 AM, Dirk Zimoch <[email protected]
<mailto:[email protected]>> wrote:
On 22.11.2017 13:28, Dirk Zimoch wrote:
The vxWorks 6.2 and 6.3 builds failed here:
In file included from
/usr/local/epics/base-7.0.1/include/os/vxWorks/boost/smart_ptr/detail/spinlock_pool.hpp:25,
                from
/usr/local/epics/base-7.0.1/include/os/vxWorks/boost/smart_ptr/shared_ptr.hpp:38,
                from
/usr/local/epics/base-7.0.1/include/os/vxWorks/boost/shared_ptr.hpp:17,
                from
/usr/local/epics/base-7.0.1/include/os/vxWorks/boost/tr1/memory.hpp:56,
                from ../../src/misc/pv/sharedPtr.h:133,
                from ../pv/pvType.h:41,
                from ../pv/pvIntrospect.h:17,
                from ../pv/pvData.h:24,
                from ../../src/json/print.cpp:11:
/usr/local/epics/base-7.0.1/include/os/vxWorks/boost/smart_ptr/detail/spinlock.hpp:47:52:
boost/smart_ptr/detail/spinlock_pt.hpp: No such file or directory
When comparing with vxWorks 6.6 and 6.7, I see the following includes:
/usr/local/epics/base-7.0.1/include/os/vxWorks/boost/smart_ptr/detail/spinlock_sync.hpp
That means in spinlock.hpp vxWorks 6.6 and 6.7 take the branch
#elif defined( BOOST_SP_HAS_SYNC )
#  include <boost/smart_ptr/detail/spinlock_sync.hpp>
But vxWorks 6.2 and 6.3 want to take the branch
#elif defined(BOOST_HAS_PTHREADS)
#  include <boost/smart_ptr/detail/spinlock_pt.hpp>
I checked that vxWorks 6 indeed defines _POSIX_THREADS as checked in
posix_features.hpp:
     // POSIX defines _POSIX_THREADS > 0 for pthread support,
     // however some platforms define _POSIX_THREADS without
     // a value, hence the (_POSIX_THREADS+0 >= 0) check.
     // Strictly speaking this may catch platforms with a
     // non-functioning stub <pthreads.h>, but such occurrences should
     // occur very rarely if at all.
#     if defined(_POSIX_THREADS) && (_POSIX_THREADS+0 >= 0) &&
!defined(BOOST_HAS_WINTHREADS) && !defined(BOOST_HAS_MPTASKS)
#        define BOOST_HAS_PTHREADS
#     endif
But the file boost/smart_ptr/detail/spinlock_pt.hpp is missing. I
copied it from another boost installation to see what happens.
VxWorks 6.2 has pthread_mutex_lock(). It implements it with semTake()
but does some magic before to follow posix rules. Maybe it is better
to use semTake directly in a vxWorks specific implementation?
Also I don't think that vxWorks 6.2 supports multi-core processors.
Thus intLock() may be faster and still safe?
Now I get another error with vxWorks 6.2:
In file included from ../../src/misc/pvUnitTest.cpp:12:
../../src/misc/pv/pvUnitTest.h: In function `detail::testPassx
  testFieldEqual(const boost::shared_ptr<const
epics::pvData::PVStructure>&,
  const char*, typename PVD::value_type)':
../../src/misc/pv/pvUnitTest.h:156: error: syntax error before `>' token
../../src/misc/pv/pvUnitTest.h:158: error: syntax error before `>' token
../../src/misc/pv/pvUnitTest.h:160: error: syntax error before `>' token
  const char*, typename PVD::const_svector)':
../../src/misc/pv/pvUnitTest.h:177: error: syntax error before `>' token
And with vxWorks 6.3:
/afs/psi.ch/project/vxworks/WindRiverGPP3.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/../lib/gcc/powerpc-wrs-vxworks/3.4.4/../../../../include/c++/3.4.4/xstring:
<http://psi.ch/project/vxworks/WindRiverGPP3.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/../lib/gcc/powerpc-wrs-vxworks/3.4.4/../../../../include/c++/3.4.4/xstring:>
In function `void testLogicException()':
/afs/psi.ch/project/vxworks/WindRiverGPP3.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/../lib/gcc/powerpc-wrs-vxworks/3.4.4/../../../../include/c++/3.4.4/xstring:78:
<http://psi.ch/project/vxworks/WindRiverGPP3.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/../lib/gcc/powerpc-wrs-vxworks/3.4.4/../../../../include/c++/3.4.4/xstring:78:>
internal compiler error: in expand_expr_real, at expr.c:8417
Please submit a full bug report,
with preprocessed source if appropriate.
Contact [email protected] <mailto:[email protected]> for
instructions.
Re: EPICS 7.0.1-pre1 (spinlock.hpp) Andrew Johnson
EPICS 7.0.1-pre1 Andrew Johnson
Re: EPICS 7.0.1-pre1 Dirk Zimoch
Re: EPICS 7.0.1-pre1 (spinlock.hpp) Dirk Zimoch
Re: EPICS 7.0.1-pre1 (spinlock.hpp) Johnson, Andrew N.
Prev: Re: EPICS 7.0.1-pre1 (spinlock.hpp) Johnson, Andrew N.
Next: Re: EPICS 7.0.1-pre1 (client.cpp) Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: Re: EPICS 7.0.1-pre1 (spinlock.hpp) Andrew Johnson
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
