On 11/23/2017 06:56 AM, Dirk Zimoch wrote:
> https://gcc.gnu.org/bugs/#cxx_rvalbind
Well, that explains it. Thanks Dirk.
> On 23.11.2017 12:03, Dirk Zimoch wrote:
>> On 23.11.2017 11:19, Dirk Zimoch wrote:
>>> Clang 3.4.2 gives an interesting hint with its warnings. It seems that
>>> this call creates a temporary, for which of course a copy is needed. If
>>> you wanted to detect accidental copies, this is such a case.
>> I have analyzed the code a bit.
>> The message was:
>> "C++98 requires an accessible copy constructor for class 'FieldName'
>> when binding a reference to a temporary"
>> The line in question is:
>> pvif(channel->pv->builder->attach(channel->pv->chan, pvf, FieldName()))
>> This is the constructor call of pvif in the constructor of PDBSinglePut.
>> It is true, that a temporary is used here. FieldName() creates an object
>> that falls out of scope immediately after the attach() call.
>> The compiler cannot know what builder->attach() will do with with the
>> temporary. It has to expect the worst, which is to keep a reference to
>> the temporary FieldName object after the attach() call has returned.
>> Since this would then reference an invalid object.
>> So maybe the compiler rather implicitly creates a copy of which
>> builder->attach can keep a reference, like this: attach(new
>> FieldName(FieldName()))
>> I need to check the C++ standard to see what the documented behavior is
>> in such a case.
- EPICS 7.0.1-pre1 Andrew Johnson
- Re: EPICS 7.0.1-pre1 Dirk Zimoch
- Re: EPICS 7.0.1-pre1 (pdbsingle.cpp) Michael Davidsaver
- Re: EPICS 7.0.1-pre1 (pdbsingle.cpp) Dirk Zimoch
Re: EPICS 7.0.1-pre1 (spinlock.hpp) Dirk Zimoch
<2017>
<2017>
