Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: EPICS 7.0.1-pre1
To: Michael Davidsaver <mdavidsaver@gmail.com>, EPICS core-talk <core-talk@aps.anl.gov>
Date: Mon, 20 Nov 2017 15:16:39 +0000
On 20/11/17 16:03, "Michael Davidsaver" <mdavidsaver@gmail.com> wrote:
>On 11/20/2017 08:21 AM, Timo Korhonen wrote:
>> Hi,
>> During the weekend I downloaded and built the EPICS 7 tarball on my
>>(own)
>> computer, KDE Neon distro, based on Ubuntu 16.04.
>> Compiles all fine. All new modules are there in the source tree, as
>> expected. All good, thanks to everybody and congratulations!
>I'm guessing that the oddness that Andrew and Heinz see has something to
>do with the version of 'tar' involved (Debian 9 has tar 1.29).
I did not notice any oddness.
Unrelated to this, I had an old RELEASE.local around in a directory above
the base and scratched my head for a while why make in the base-7
directory picked up the wrong version...embarrassing to tell but was easy
to solve.
>> However, I had the (perhaps naïve) expectation that when I use
>> makeBaseApp, I would get an doc with QSRV. This was not the case.
>> The next try was to follow Michael's instructions from the Barcelona
>> meeting, to add the QSRV definitions in the Makefile. Still no luck.
>> After hacking a while I managed to create an IOC with QSRV, but it was
>>not
>> exactly straightforward. I assume a newcomer would be confused.
>> I just wonder if this is the expected state? Maybe I am just missing
>> something obvious.
>What problems did you encounter?  I've been working on documentation,
>and user feedback is the best (and maybe only) way to make this useful.
>https://github.com/epics-base/pva2pva/blob/master/documentation/mainpage.h
I try to repeat what I did and this time carefully note down all issues
that I encounter. During last weekend was just a quick exercise, I had a
bunch of other things to do at home so I was not very meticulous and just
wanted quick results.
Timo
Re: EPICS 7.0.1-pre1 Heinz Junkes
Re: EPICS 7.0.1-pre1 Michael Davidsaver
EPICS 7.0.1-pre1 Andrew Johnson
Re: EPICS 7.0.1-pre1 Timo Korhonen
Prev: Re: EPICS 7.0.1-pre1 Michael Davidsaver
Next: Re: EPICS 7.0.1-pre1 Heinz Junkes
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
ANJ, 20 Nov 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
