Hi Michael,
On 10/31/2017 03:35 PM, Michael Davidsaver wrote:
> Yup. I have a recipe developed with another module. I'd forgotten
> about this as well, but will make the changes.
Similar problem in pva2pva/pdbApp/configparse.cpp:
> make[2]: Entering directory '/local/anj/base-7.0/modules/pva2pva/pdbApp/O.linux-x86_64'
> /usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"/local/anj/base-7.0\"" -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -Wpointer-arith -fvisibility=hidden -fvisibility-inlines-hidden -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -c ../configparse.cpp
> ../configparse.cpp:195:1: error: invalid conversion from ‘int (*)(void*, long int)’ to ‘int (*)(void*, long long int)’ [-fpermissive]
> ../configparse.cpp:195:1: error: invalid conversion from ‘int (*)(void*, const unsigned char*, unsigned int)’ to ‘int (*)(void*, const unsigned char*, size_t) {aka int (*)(void*, const unsigned char*, long unsigned int)}’ [-fpermissive]
> ../configparse.cpp: In static member function ‘static void GroupConfig::parse(const char*, GroupConfig&)’:
> ../configparse.cpp:215:5: error: ‘yajl_parser_config’ was not declared in this scope
> yajl_parser_config conf;
> ../configparse.cpp:215:24: error: expected ‘;’ before ‘conf’
> ../configparse.cpp:216:13: error: ‘conf’ was not declared in this scope
> memset(&conf, 0, sizeof(conf));
> ../configparse.cpp:226:13: error: ‘yajl_status_insufficient_data’ was not declared in this scope
> if(sts==yajl_status_insufficient_data)
> ../configparse.cpp:227:41: error: ‘yajl_parse_complete’ was not declared in this scope
> sts = yajl_parse_complete(handle);
> ../configparse.cpp:242:10: error: ‘yajl_status_insufficient_data’ was not declared in this scope
> case yajl_status_insufficient_data:
> ../../../../configure/RULES_BUILD:237: recipe for target 'configparse.o' failed
> make[2]: *** [configparse.o] Error 1
> make[2]: Leaving directory '/local/anj/base-7.0/modules/pva2pva/pdbApp/O.linux-x86_64'
While you're there, have you been working on fixing the earlier pva2pva
build problems on Windows and Mac?
- Andrew
- Re: pvDataCPP and yajl-2.1.0 Michael Davidsaver
- pvDataCPP and yajl-2.1.0 Andrew Johnson
Re: Base.t missing (mis-merge?) Andrew Johnson
<2017>
<2017>
