Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: Base.t missing (mis-merge?)
To: Michael Davidsaver <mdavidsaver@gmail.com>, Ralph Lange <Ralph.Lange@gmx.de>
Cc: EPICS core-talk <core-talk@aps.anl.gov>
Date: Wed, 1 Nov 2017 11:36:02 -0500
On 11/01/2017 11:04 AM, Michael Davidsaver wrote:
> I naively tried to move Base.plt to test/tools/ but this wasn't enough.
>> Can't locate DBD/Base.pm in @INC (you may need to install the DBD::Base module) (@INC contains: ../.. /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.24.1 /usr/local/share/perl/5.24.1 /usr/lib/x86_64-linux-gnu/perl5/5.24 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.24 /usr/share/perl/5.24 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at Base.t line 7.
>> BEGIN failed--compilation aborted at Base.t line 7.
There was an additional change needed to get those test scripts to find
their libraries in the new structure. I have just committed the
necessary move and fix, and travis is now building database/master
I was working on merging the latest 3.16 branch into 7.0 yesterday, but
I hadn't got to the database module yet. I'm considering if it's
possible to write a script that does most of the necessary mechanical
work associated with merging up from 3.16; so far it looks possible
because the paths are all distinct.
- Andrew
Base.t missing (mis-merge?) Michael Davidsaver
Prev: Base.t missing (mis-merge?) Michael Davidsaver
Next: Re: pvDataCPP and yajl-2.1.0 Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Next: Base status Andrew Johnson
ANJ, 01 Nov 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
