See <https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/139/display/redirect>
[...truncated 13.52 KB...]
T_A=solaris-sparc tapfiles
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/ioc/db/test/O.solaris-sparc'>
perl -CSD dbScanTest.t -tap > dbScanTest.tap
perl -CSD dbShutdownTest.t -tap > dbShutdownTest.tap
perl -CSD dbPutLinkTest.t -tap > dbPutLinkTest.tap
dbJLinkInit: lexical error: invalid char in json text.
{"x":bbbb}
(right here) ------^
dbJLinkInit: parse error: premature EOF
{"z":{"good":6}
perl -CSD dbLockTest.t -tap > dbLockTest.tap
perl -CSD dbStressTest.t -tap > dbStressTest.tap
perl -CSD testdbConvert.t -tap > testdbConvert.tap
perl -CSD callbackTest.t -tap > callbackTest.tap
perl -CSD callbackParallelTest.t -tap > callbackParallelTest.tap
perl -CSD dbStateTest.t -tap > dbStateTest.tap
perl -CSD dbCaStatsTest.t -tap > dbCaStatsTest.tap
perl -CSD dbCaLinkTest.t -tap > dbCaLinkTest.tap
perl -CSD scanIoTest.t -tap > scanIoTest.tap
perl -CSD dbChannelTest.t -tap > dbChannelTest.tap
perl -CSD dbChArrTest.t -tap > dbChArrTest.tap
Starting iocInit
rsrv: failed to set mcast ttl 1
epicsThreadRealtimeLock Warning: Unable to lock the virtual address space.
VM page faults may harm real-time performance.
perl -CSD chfPluginTest.t -tap > chfPluginTest.tap
chfConfigParseStart: plugin pvt alloc failed
perl -CSD arrShorthandTest.t -tap > arrShorthandTest.tap
perl -CSD recGblCheckDeadbandTest.t -tap > recGblCheckDeadbandTest.tap
perl -CSD testPutGetTest.t -tap > testPutGetTest.tap
perl -CSD dbStaticTest.t -tap > dbStaticTest.tap
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/ioc/db/test/O.solaris-sparc'>
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/ioc/db/test'>
make -C ioc/dbtemplate/test tapfiles
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/ioc/dbtemplate/test'>
make -C O.solaris-sparc -f ../Makefile TOP=../../../../.. \
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/ioc/dbtemplate/test/O.solaris-sparc'>
perl -CSD msi.t -tap > msi.tap
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/ioc/dbtemplate/test/O.solaris-sparc'>
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/ioc/dbtemplate/test'>
make -C ./std tapfiles
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std'>
make -C O.solaris-sparc -f ../Makefile TOP=../../.. \
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std/O.solaris-sparc'>
make[2]: Nothing to be done for 'tapfiles'.
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std/O.solaris-sparc'>
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std'>
make -C std/filters/test tapfiles
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std/filters/test'>
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std/filters/test/O.solaris-sparc'>
perl -CSD tsTest.t -tap > tsTest.tap
perl -CSD dbndTest.t -tap > dbndTest.tap
perl -CSD arrTest.t -tap > arrTest.tap
perl -CSD syncTest.t -tap > syncTest.tap
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std/filters/test/O.solaris-sparc'>
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std/filters/test'>
make -C std/rec/test tapfiles
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std/rec/test'>
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std/rec/test/O.solaris-sparc'>
perl -CSD arrayOpTest.t -tap > arrayOpTest.tap
perl -CSD recMiscTest.t -tap > recMiscTest.tap
perl -CSD linkRetargetLinkTest.t -tap > linkRetargetLinkTest.tap
perl -CSD linkInitTest.t -tap > linkInitTest.tap
perl -CSD compressTest.t -tap > compressTest.tap
perl -CSD asyncSoftTest.t -tap > asyncSoftTest.tap
perl -CSD softTest.t -tap > softTest.tap
perl -CSD asTest.t -tap > asTest.tap
perl -CSD analogMonitorTest.t -tap > analogMonitorTest.tap
Starting iocInit
perl -CSD regressTest.t -tap > regressTest.tap
dbConvertJSON: parse error: trailing garbage
0x10
0x10
0x10
0x10
0x10
0x10
0x10
0x10
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std/rec/test/O.solaris-sparc'>
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std/rec/test'>
make: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src'>
+ make -s test-results
Base.tap ........ ok
Breaktable.tap .. ok
DBD.tap ......... ok
Device.tap ...... ok
Driver.tap ...... ok
Function.tap .... ok
macLib.tap ...... ok
Menu.tap ........ ok
Recfield.tap .... ok
Recordtype.tap .. ok
Registrar.tap ... ok
Snippets.tap .... ok
Variable.tap .... ok
All tests successful.
Files=13, Tests=351, 0 wallclock secs ( 0.11 usr + 0.07 sys = 0.18 CPU)
Result: PASS
epicsUnitTestTest.tap ........ ok
epicsTypesTest.tap ........... ok
epicsInlineTest.tap .......... ok
epicsCalcTest.tap ............ ok
epicsAlgorithmTest.tap ....... ok
epicsMathTest.tap ............ ok
epicsMMIOTest.tap ............ ok
epicsEllTest.tap ............. ok
epicsEnvTest.tap ............. ok
epicsErrlogTest.tap .......... ok
epicsStdioTest.tap ........... ok
epicsStdlibTest.tap .......... ok
epicsSockResolveTest.tap ..... ok
epicsStringTest.tap .......... ok
epicsTimeTest.tap ............ ok
epicsTimeZoneTest.tap ........ ok
epicsThreadTest.tap .......... ok
epicsThreadOnceTest.tap ...... ok
epicsThreadPriorityTest.tap .. ok
epicsThreadPrivateTest.tap ... ok
epicsThreadHooksTest.tap ..... ok
epicsThreadPoolTest.tap ...... ok
epicsExitTest.tap ............ ok
epicsTimerTest.tap ........... ok
ringPointerTest.tap .......... ok
ringBytesTest.tap ............ ok
epicsEventTest.tap ........... ok
epicsMutexTest.tap ........... ok
epicsSpinTest.tap ............ ok
epicsAtomicTest.tap .......... ok
macDefExpandTest.tap ......... ok
cvtFastTest.tap .............. ok
macLibTest.tap ............... ok
taskwdTest.tap ............... ok
blockingSockTest.tap ......... ok
epicsMessageQueueTest.tap .... ok
epicsStackTraceTest.tap ...... ok
ipAddrToAsciiTest.tap ........ ok
osiSockTest.tap .............. ok
yajlTest.tap ................. ok
Files=40, Tests=4035, 1 wallclock secs ( 0.59 usr + 0.20 sys = 0.79 CPU)
Result: PASS
dbScanTest.tap ............... ok
dbShutdownTest.tap ........... ok
dbPutLinkTest.tap ............ ok
dbLockTest.tap ............... ok
dbStressTest.tap ............. ok
testdbConvert.tap ............ ok
callbackTest.tap ............. ok
callbackParallelTest.tap ..... ok
dbStateTest.tap .............. ok
dbCaStatsTest.tap ............ ok
dbCaLinkTest.tap ............. ok
scanIoTest.tap ............... ok
dbChannelTest.tap ............ ok
dbChArrTest.tap .............. ok
chfPluginTest.tap ............ ok
arrShorthandTest.tap ......... ok
recGblCheckDeadbandTest.tap .. ok
testPutGetTest.tap ........... ok
dbStaticTest.tap ............. ok
Files=19, Tests=2809, 1 wallclock secs ( 0.43 usr + 0.10 sys = 0.53 CPU)
Result: PASS
msi.tap .. ok
Files=1, Tests=9, 0 wallclock secs ( 0.04 usr + 0.01 sys = 0.05 CPU)
Result: PASS
tsTest.tap .... ok
dbndTest.tap .. ok
arrTest.tap ... ok
syncTest.tap .. ok
Files=4, Tests=1612, 0 wallclock secs ( 0.25 usr + 0.03 sys = 0.28 CPU)
Result: PASS
arrayOpTest.tap ........... ok
recMiscTest.tap ........... ok
linkRetargetLinkTest.tap .. ok
linkInitTest.tap .......... ok
compressTest.tap .......... ok
asyncSoftTest.tap .........
not ok 38 - dbGetField("bi1", 5) -> 1 == 0
not ok 52 - dbGetField("di1", 5) -> 9 == 0
not ok 73 - dbGetField("mi1", 5) -> 9 == 0
Failed 3/128 subtests
softTest.tap ..............
not ok 44 - dbGetField("bi1", 5) -> 1 == 0
not ok 48 - dbGetField("di1", 5) -> 9 == 0
not ok 56 - dbGetField("mi1", 5) -> 9 == 0
Failed 3/114 subtests
asTest.tap ................ ok
analogMonitorTest.tap ..... ok
regressTest.tap ........... ok
Test Summary Report
asyncSoftTest.tap (Wstat: 0 Tests: 128 Failed: 3)
Failed tests: 38, 52, 73
softTest.tap (Wstat: 0 Tests: 114 Failed: 3)
Failed tests: 44, 48, 56
Files=10, Tests=2350, 0 wallclock secs ( 0.33 usr + 0.06 sys = 0.39 CPU)
Result: FAIL
../../../../../configure/RULES_BUILD:350: recipe for target 'test-results' failed
make[3]: *** [test-results] Error 1
../../../../configure/RULES_ARCHS:58: recipe for target 'test-results.solaris-sparc' failed
make[2]: *** [test-results.solaris-sparc] Error 2
../configure/RULES_DIRS:84: recipe for target 'std/rec/test.test-results' failed
make[1]: *** [std/rec/test.test-results] Error 2
configure/RULES_DIRS:84: recipe for target 'src.test-results' failed
make: *** [src.test-results] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.solaris-sparc/*.tap
Saving reports...
There are failed test cases. Marking build as UNSTABLE
TAP Reports Processing: FINISH
- Build failed in Jenkins: epics-base-3.16-sol-test #140 APS Jenkins
- Build failed in Jenkins: epics-base-3.16-sol-test #138 APS Jenkins
Build failed in Jenkins: epics-base-3.16-mac-test #163 APS Jenkins
Jenkins build is back to normal : epics-base-3.16-mac-test #164 APS Jenkins
<2017>
<2017>
