Subject: |
Re: Adding userTag to epicsTimeStamp |
"Johnson, Andrew N." <[email protected]> |
To: |
EPICS core-talk <[email protected]> |
Date: |
Tue, 10 Oct 2017 13:23:04 +0000 |
Thanks for all the discussion, I appreciate everyone’s thoughts about this idea.
I am not now considering this for inclusion in EPICS 7.0, I think it’s too late to be adding this kind of a change, but the proof of concept and the responses are encouraging enough that I think this should be something we include in 7.1 – there are enough sites wanting it that the IOC should be able to record a userTag in record timestamps. Whether it should be 32 or 64 bits and signed or unsigned is something that should be considered separately based on input from those asking for it.
Marty: if you think you have found bugs in the PVTimeStamp code which should be fixed even without making this addition to the IOC, feel free to go ahead and create a pull request to fix them.
I have filed a bug in Launchpad to keep track of this enhancement proposal, see https://bugs.launchpad.net/epics-base/+bug/1722530 which also refers to this thread.
- Andrew
> On Oct 10, 2017, at 12:14 PM, Marty Kraimer <[email protected]> wrote:
> On 10/09/2017 11:09 AM, Kasemir, Kay wrote:
>>> Not saying that this specific tag should not be 64 bits wide, but to change an existing approved design,
>>> I would like to see a minimum amount of justification and discussion.
>> A time tag change from 32 to 64 bits makes no difference to those who simply use pvAccess via qsrv/pvaSrv since the EPICS database never provided a value, anyway.
>> And even though the time stamp is part of most updates, if I understand correctly this change will hardly affect the network package size because when you leave the tag at its default value of 0 and don't change, the monitor deltas won't include the tag, only the secs & nanosecs, correct?
> Not quite but can be fixed.
> I think the only problem is in the timeStamp support code.
> In particular
>> bool PVTimeStamp::set(TimeStamp const & timeStamp)
>> if(pvSecs.get()==NULL) {
>> throw std::logic_error(notAttached);
>> if(pvSecs->isImmutable() || pvNano->isImmutable()) return false;
>> pvSecs->put(timeStamp.getSecondsPastEpoch());
>> pvUserTag->put(timeStamp.getUserTag());
>> pvNano->put(timeStamp.getNanoseconds());
>> return true;
> Note that it always sets userTag. The same problem exists in Java.
> Both timeStamp and pvTimeStamp require changes in both Java and C++.
> I agree that going to a 64 bit integer is a good idea.
> But it should be a signed 64 bit integer for two reasons:
> 1) Keeps better compatibility between Java and C++.
> 2) The other fields of a timeStamp are signed, which is useful for computing time differences.
> If we are going to make this change for first release of EPICS 7 changes must be made soon in both C++ and Java.
> Will this also require changes to any of normativeTypes, pvaPy, and p4p?
> Will this cause compatibility problems?
> Marty
>> The SNS beam line neutron data does use the user tag for a sequence number, incremented by server to allow double-checking for missing updates. So our software might need to be updated. I believe this could be done beam line by beam line, won't be a show stopper.
>> -Kay
- Re: Adding userTag to epicsTimeStamp Marty Kraimer
- Adding userTag to epicsTimeStamp Johnson, Andrew N.
- Re: Adding userTag to epicsTimeStamp Ralph Lange
- RE: Adding userTag to epicsTimeStamp Mark Rivers
- Re: Adding userTag to epicsTimeStamp Kasemir, Kay
Re: Adding userTag to epicsTimeStamp Benjamin Franksen
<2017>
<2017>
