Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: Adding userTag to epicsTimeStamp
To: "core-talk@aps.anl.gov" <core-talk@aps.anl.gov>
Date: Mon, 9 Oct 2017 15:09:53 +0000
>Not saying that this specific tag should not be 64 bits wide, but to change an existing approved design,
>I would like to see a minimum amount of justification and discussion.
A time tag change from 32 to 64 bits makes no difference to those who simply use pvAccess via qsrv/pvaSrv since the EPICS database never provided a value, anyway.
And even though the time stamp is part of most updates, if I understand correctly this change will hardly affect the network package size because when you leave the tag at its default value of 0 and don't change, the monitor deltas won't include the tag, only the secs & nanosecs, correct?
The SNS beam line neutron data does use the user tag for a sequence number, incremented by server to allow double-checking for missing updates. So our software might need to be updated. I believe this could be done beam line by beam line, won't be a show stopper.
-Kay
Re: Adding userTag to epicsTimeStamp Marty Kraimer
Re: Adding userTag to epicsTimeStamp Michael Davidsaver
Adding userTag to epicsTimeStamp Johnson, Andrew N.
Re: Adding userTag to epicsTimeStamp Ralph Lange
RE: Adding userTag to epicsTimeStamp Mark Rivers
Prev: RE: Adding userTag to epicsTimeStamp Mark Rivers
Next: Build failed in Jenkins: epics-base-3.16-mac-test #155 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Next: Re: Adding userTag to epicsTimeStamp Marty Kraimer
ANJ, 12 Oct 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
