2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: base-3.16.1 bug
To: <[email protected]>, Marty Kraimer <[email protected]>
Date: Thu, 7 Sep 2017 13:50:17 -0500
Fix and new tests committed to the Base-3.16 branch.
- Andrew
On 09/06/2017 06:17 PM, Andrew Johnson wrote:
> On 09/06/2017 12:12 PM, Michael Davidsaver wrote:
>> @Andrew Will you be adding a test to trigger this regression before
>> fixing it?  src/std/rec/test/regressTest.c would be a easy place.
> I had already started creating a new softTest program, analogous to the
> asyncSoftTest code already under std/rec/test. Will finish off tomorrow.
>>> I would say the dummy method returning OK is the way to go. Other link
>>> types might return errors that are worth reporting, and it is certainly
>>> a property of the CONSTANT link that a put() operation is never
>>> producing an error.
>> I agree with this.
> Thanks for responding.
>> Another inconsistency.  CA put w/ callback is losing the error.  I see
>> that dbNotify ignores the result of dbProcess().  It would be nice if it
>> didn't...
> That's a whole other level of complexity, the result would have to be
> saved in the processNotify object by dbNotify and then retrieved and
> returned to the client by the rsrv callback routine — the first part is
> easy, but the second isn't obvious...
>> I also noticed that dbNotify doesn't propagate some errors in it's
>> putCallback for link fields.
> Similar, I think that's a different bug (and I shouldn't really have
> been spending time writing tests for the original problem at the moment,
> but I did).
> - Andrew
Re: base-3.16.1 bug Andrew Johnson
Re: base-3.16.1 bug Ralph Lange
Re: base-3.16.1 bug Michael Davidsaver
Prev: Re: base-3.16.1 bug Andrew Johnson
Next: Re: Developers Meetings @ ITER, Oct 2017 Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: asynManager changes Mark Rivers
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
