On 09/06/2017 12:12 PM, Michael Davidsaver wrote:
> @Andrew Will you be adding a test to trigger this regression before
> fixing it? src/std/rec/test/regressTest.c would be a easy place.
I had already started creating a new softTest program, analogous to the
asyncSoftTest code already under std/rec/test. Will finish off tomorrow.
>> I would say the dummy method returning OK is the way to go. Other link
>> types might return errors that are worth reporting, and it is certainly
>> a property of the CONSTANT link that a put() operation is never
>> producing an error.
> I agree with this.
Thanks for responding.
> Another inconsistency. CA put w/ callback is losing the error. I see
> that dbNotify ignores the result of dbProcess(). It would be nice if it
> didn't...
That's a whole other level of complexity, the result would have to be
saved in the processNotify object by dbNotify and then retrieved and
returned to the client by the rsrv callback routine — the first part is
easy, but the second isn't obvious...
> I also noticed that dbNotify doesn't propagate some errors in it's
> putCallback for link fields.
Similar, I think that's a different bug (and I shouldn't really have
been spending time writing tests for the original problem at the moment,
but I did).
- Andrew
- Re: base-3.16.1 bug Andrew Johnson
- Re: base-3.16.1 bug Ralph Lange
- Re: base-3.16.1 bug Michael Davidsaver
<2017>
<2017>
