2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c
From: "Williams Jr., Ernest L." <[email protected]>
To: Andrew Johnson <[email protected]>, Michael Davidsaver <[email protected]>
Cc: "[email protected]" <[email protected]>, "Slepicka, Hugo Henrique" <[email protected]>
Date: Wed, 23 Aug 2017 20:44:19 +0000
Hi Andrew,
Thanks.  :)
I will apply the recommended patch from the "Known Problems page"
Cheers,
Ernest Williams
Dept. Head, Advanced Control Systems
Advanced Instrumentation Research, Technology Innovation Directorate
SLAC National Laboratory, Stanford University
Sent: Wednesday, August 23, 2017 12:32 PM
To: Michael Davidsaver
Cc: Williams Jr., Ernest L.; Heinz Junkes; [email protected]; Slepicka, Hugo Henrique
Subject: Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c
On 08/23/2017 01:31 PM, Michael Davidsaver wrote:
> This seems a reasonable way to go if test coverage is added as well.
Ok, the attached patch does everything except add the test coverage,
which will take me a little while to implement. I have cross-built the
result with MinGW but not MSVC yet. I will add this patch to the 3.15.5
Known Problems page so Ernest can use it, but I won't commit anything to
Git until I have the tests to go along with it.
I reserve the right to change my mind about using blockingSockTest.cpp
for these tests.
- Andrew
RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Heinz Junkes
Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Heinz Junkes
Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Michael Davidsaver
Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Andrew Johnson
RE: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Williams Jr., Ernest L.
Prev: Re: Still can not successful compile/run epicsV4CPP from github Heinz P. Junkes
Next: Re: Still can not successful compile/run epicsV4CPP from github Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Andrew Johnson
Next: Build failed in Jenkins: epics-base-3.15-win32 #275 APS Jenkins
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
