Hi Michael,
Thanks for taking a look - I see the MinGW cross compile running under Wine can't translate most of the symbols
# Dumping a stack trace of thread 'win9':
# [ 707A6EEF]
# [ 707A6DB3]
# [ 0040159B]
# [ 004015C8]
# [ 00401592]
# [ 004015C8]
# [ 004018A6]
# [ 004013E3]
# [ 7B46A1C9](call_process_entry+0x19)
# [ 7B46B99C]
# [ 7BCB350C](call_thread_func_wrapper+0xc)
# [ 7BCB6E1B]
# [ 7BCB34EA](RtlRaiseException+0x5a)
# [ 7BC7E43C](call_dll_entry_point+0x6ac)
# [ F758618D]
If I copy the cross-compiled executable and DLLs across to windows it manages to do a little better and translate the public symbols in Com.dll
# Dumping a stack trace of thread 'win72c4':
# [ 707A6EEF](epicsBackTrace+0x37)
# [ 707A6DB3](epicsStackTrace+0x57)
# [ 0040159B]
# [ 004015C8]
# [ 00401592]
# [ 004015C8]
# [ 004018A6]
# [ 004013E3]
# [ 74DE336A](BaseThreadInitThunk+0x12)
# [ 76FF9902](RtlInitializeExceptionChain+0x63)
# [ 76FF98D5](RtlInitializeExceptionChain+0x36)
Freddie
-----Original Message-----
From: Michael Davidsaver [mailto:[email protected]]
Sent: 08 August 2017 17:59
To: Akeroyd, Freddie (STFC,RAL,ISIS); [email protected]
Subject: Re: epicsStackTrace on WIN32
For my part, looks ok. I can compile/run epicsStackTraceTest.exe with cross mingw/WINE. The parts which WINE implements appear to work (numeric addresses).
Makefile changes for testing:
https://github.com/mdavidsaver/epics-base/commit/e2496521fd46a353ef28fe9d2cf9d6a863e07696
On 08/08/2017 01:53 PM, [email protected] wrote:
> Hi,
> I'd noticed that epicsStackTrace() didn't translate symbols on Windows and enclose an implementation of osdFindAddr.c for WIN32. In addition to adding the file, the following build file changes would be required too:
> "dbghelp" needs adding to Com_SYS_LIBS_WIN32 in src/libCom/Makefile
> "dbghelp.lib" needs adding to STATIC_LDLIBS_YES in CONFIG.win32-x86.win32-x86
> I expect "-ldbghelp" might need adding to OP_SYS_LDLIBS for MinGW
> builds (CONFIG.linux-x86.win32-x86-mingw and
> CONFIG.win32-x86-mingw.win32-x86-mingw) but I've not verified
> Regards,
> Freddie
- epicsStackTrace on WIN32 freddie.akeroyd
- Re: epicsStackTrace on WIN32 Michael Davidsaver
RE: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Williams Jr., Ernest L.
<2017>
Add optimization switch to compiler dependencies Ralph Lange
<2017>
