2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: epicsStackTrace on WIN32
To: <[email protected]>
Date: Tue, 8 Aug 2017 11:53:53 +0000
I'd noticed that  epicsStackTrace()  didn't translate symbols on Windows and enclose an implementation of  osdFindAddr.c  for WIN32. In addition to adding the file,  the following build file changes would be required too:
"dbghelp" needs adding to  Com_SYS_LIBS_WIN32  in  src/libCom/Makefile
"dbghelp.lib"  needs adding to  STATIC_LDLIBS_YES   in  CONFIG.win32-x86.win32-x86
I expect "-ldbghelp" might need adding to  OP_SYS_LDLIBS  for MinGW builds (CONFIG.linux-x86.win32-x86-mingw and CONFIG.win32-x86-mingw.win32-x86-mingw) but I've not verified
Freddie
* Copyright (C) 2017 Science and Technology Facilities Council.
* EPICS BASE is distributed subject to a Software License Agreement found
* in file LICENSE that is included with this distribution.
 *      Author: Freddie Akeroyd (STFC)
#include <windows.h>
#include <dbghelp.h>
#define epicsExportSharedSymbols
#include "epicsStackTracePvt.h"
#include "epicsStackTrace.h"
#include "epicsString.h"
#include "epicsStdio.h"
#include "gpHash.h"
#define MAX_SYM_SIZE 255
 * we cache a list of previously located symbols, currently just to
 * avoid a memory leak in allocating  sym_p->s_nam  and not
 * to save on a  SymFromAddr()  call. This was done in case libraries
 * were dynamically unloaded/reloaded and the cached answer might not
 * then be correct, but this may be over cautious.
static struct gphPvt* symbol_table;
typedef struct
    char* name;
    void* value;
    char* file;
    char* fileAndLine;
    size_t line;
} SymbolData;
int epicsFindAddr(void *addr, epicsSymbol *sym_p)
	static int first_call = 1;
	static HANDLE process = NULL;
	DWORD64 displacement64 = 0;
	DWORD displacement = 0;
	SYMBOL_INFO *symbol;
	IMAGEHLP_LINE64 line;
    GPHENTRY* symbol_entry;
    SymbolData* symbol_data;
    size_t len;
	if (first_call)
		SymSetOptions(SYMOPT_LOAD_LINES | SYMOPT_DEFERRED_LOADS);
		process = GetCurrentProcess();
		SymInitialize(process, NULL, TRUE);
        gphInitPvt(&symbol_table, 256); /* table size must be a power of 2 in range 256 to 65536 */
		first_call = 0;
	symbol = (SYMBOL_INFO *)calloc(sizeof(SYMBOL_INFO) + (MAX_SYM_SIZE + 1) * sizeof(char), 1);
	symbol->MaxNameLen = MAX_SYM_SIZE;
	symbol->SizeOfStruct = sizeof(SYMBOL_INFO);
	if (!SymFromAddr(process, (DWORD64)addr, &displacement64, symbol))
		sym_p->s_nam = 0;
		sym_p->s_val = 0;
		sym_p->f_nam = 0;
		free(symbol);
		return -1;
    if ( (symbol_entry = gphFind(symbol_table, symbol->Name, addr)) != NULL )
        symbol_data = (SymbolData*)symbol_entry->userPvt;
    else
        symbol_entry = gphAdd(symbol_table, symbol->Name, addr);
        symbol_data = (SymbolData*)calloc(sizeof(SymbolData), 1);
	    symbol_data->name = strdup(symbol->Name);
	    symbol_data->value = (void*)symbol->Address;
	    line.SizeOfStruct = sizeof(IMAGEHLP_LINE64);
	    if (SymGetLineFromAddr64(process, (DWORD64)addr, &displacement, &line))
	        symbol_data->file = strdup(line.FileName);
	        symbol_data->line = line.LineNumber;
            len = strlen(line.FileName) + 32; /* add enough for [line %lu] */
	        symbol_data->fileAndLine = calloc((len + 1) * sizeof(char), 1);
            epicsSnprintf(symbol_data->fileAndLine, len, "%s[line %lu]", line.FileName, (unsigned long)line.LineNumber);
        symbol_entry->userPvt = symbol_data;
	sym_p->s_nam = symbol_data->name;
	sym_p->s_val = symbol_data->value;
	sym_p->f_nam = symbol_data->fileAndLine;
	free(symbol);
	return 0;
int epicsFindAddrGetFeatures(void)
	return  EPICS_STACKTRACE_LCL_SYMBOLS
		| EPICS_STACKTRACE_GBL_SYMBOLS
		| EPICS_STACKTRACE_DYN_SYMBOLS;
Re: epicsStackTrace on WIN32 Michael Davidsaver
Prev: Re: EPICS Base module split / bundle build (EPICS 7 prep) ready to test Ralph Lange
Next: Re: epicsStackTrace on WIN32 Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS Base module split / bundle build (EPICS 7 prep) ready to test Hartman, Steven M.
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
