Subject: |
binding trouble if Port is already in use, src/ioc/rsrv/caservertask.c |
Heinz Junkes <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 8 Jun 2017 10:27:57 +0200 |
when I try to run an ioc on a system (linux-x86_64) where still some other ioc’s are running (standard Port in use) I see
## EPICS R3.16.0.1-DEV-fhi
## EPICS Base built Jun 8 2017
xWidth = 100, yHeight = 100
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 36485,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
tryBind (Addr: 0xa141e01, Port: 5064) <————————— my debug output Addr 10.20.30.1, just bevor tryBind
tryBind failed (Addr: 0xa141e01, Port: 5064) < ———————————— my debug output, tryBind failed (line 133 src/ioc/rsrv/caservertask.c)
CAS: No TCP server started
Thread _main_ (0x19c3f50) can't proceed, suspending.
Dumping a stack trace of thread '_main_':
[ 0x7ff760d43303]: /home/rtems/EPICS/add-rtems-4.12-api/lib/linux-x86_64/libCom.so.3.16.0(epicsStackTrace+0x73)
[ 0x7ff760d32c05]: /home/rtems/EPICS/add-rtems-4.12-api/lib/linux-x86_64/libCom.so.3.16.0(cantProceed+0xc5)
[ 0x7ff75fa2801a]: /home/rtems/EPICS/add-rtems-4.12-api/lib/linux-x86_64/libdbCore.so.3.16.0(rsrv_init+0x104a)
[ 0x7ff75fa24bfb]: /home/rtems/EPICS/add-rtems-4.12-api/lib/linux-x86_64/libdbCore.so.3.16.0(iocBuild+0x2b)
[ 0x7ff75fa24d89]: /home/rtems/EPICS/add-rtems-4.12-api/lib/linux-x86_64/libdbCore.so.3.16.0(iocInit+0x9)
[ 0x7ff760d2d4e7]: /home/rtems/EPICS/add-rtems-4.12-api/lib/linux-x86_64/libCom.so.3.16.0(iocshBody+0xc17)
[ 0x409b92]: ../../bin/linux-x86_64/IOCCryvisil(main+0x12)
[ 0x7ff75ed84830]: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)
[ 0x409be9]: ../../bin/linux-x86_64/IOCCryvisil(_start+0x29)
Defining
epicsEnvSet("EPICS_CAS_SERVER_PORT","5066”)
in st.cmd solves the problem :
Starting iocInit
tryBind (Addr: 0xa141e01, Port: 5066)
## Start any sequence programs
#seq(sncxxx, "user=rtems")
#startPVAServer
epics>
I am not using the actual src/ioc/rsrv/caservertask.c with the “autoMaxBytes” extension.
Heinz
smime.p7s
Description: S/MIME cryptographic signature
- Re: binding trouble if Port is already in use, src/ioc/rsrv/caservertask.c Michael Davidsaver
Re: terminate called after throwing an instance of 'epicsMutex::invalidMutex' Marty Kraimer
<2017>
RE: Build problem Mark Rivers
<2017>
