On 06/04/2017 09:16 PM, Marty Kraimer wrote:
> On 06/04/2017 01:32 PM, Heinz Junkes wrote:
>> I replaced pvaClientCPP and pvAccessCPP with the code you provide
>> Now the tests runs without error:
> Good news!!!
> I did make some more changes to
> https://github.com/mrkraimer/pvAccessCPP/
> The changes resulted from suggestions made by Michael Davidsaver.
Well, at least some of them.
FYI. this is what I'm doing
https://github.com/mdavidsaver/pvAccessCPP/commit/6926d911eeb1b8ccb4da14ed7717f381379a7434
This is only the first part though, dealing with the problems in
caProvider.cpp.
The larger issue I see is that the "conventional" implementations of
ChannelProviderFactory::sharedInstance() has the factory keep a strong
ChannelProvider reference.
For my work on P4P server side this was causing problems as all python
objects should be destroyed well before the global provider factory
map<> is destroyed. This resulted in an attempt to take the GIL after
it had been free'd. So if a removeProvider() is omitted, then the
process crashes on exit.
My first change is to turn this strong ref. into a weak ref. This means
that destruction of the registry no longer has side-effects related to
provider destruction.
In clearing up some potential global ctor/dtor ordering issues, the
global registry (a la. getChannelProviderRegistry() ) is no longer
free'd. As it hold only weak refs. there seemed to me no downside other
than a "reachable" leak.
- Re: terminate called after throwing an instance of 'epicsMutex::invalidMutex' Marty Kraimer
- terminate called after throwing an instance of 'epicsMutex::invalidMutex' Heinz Junkes
- Re: terminate called after throwing an instance of 'epicsMutex::invalidMutex' Heinz Junkes
RE: Build problem Mark Rivers
<2017>
<2017>
