2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: iocShutdown() hooks
Cc: EPICS core-talk <[email protected]>
Date: Wed, 31 May 2017 02:54:03 +0200
On 05/30/2017 06:42 PM, Andrew Johnson wrote:
> Hi Michael,
> On 05/25/2017 09:06 AM, Michael Davidsaver wrote:
>> I've realized that I need to hook into iocShutdown() to be able to
>> automatically shutdown QSRV during unittests.  I need to do so during
>> the "stop" phase (eg. scanStop()) before records and lockSets are free'd.
>> My first though would be to use initHooks.h.  So I'd like to add
>> * initHookAtShutdown  - at start of iocShutdown()
>> * initHookAfterCloseLinks - after dbCaShutdown()
>> * initHookAtStopped - Just after iocShutdown() returns
> No objections in principle, but a cleaner option might be to add methods
> to the dbServer structure (which QSRV should support if possible) and
> make the rsrv_init(), rsrv_run() and rsrv_pause() calls in iocInit into
> calls to all registered servers through this interface. The
> dbRegisterServer() call in rsrv_init() would move into a registrar
> routine referenced in a new rsrv.dbd file.
I'm going to add the (de) initHooks anyway as this is something would
have been helpful to me before for driver work.
I don't see what you're getting at wrt. dbServer.  How would this be
cleaner than an initHook?   Seems the same to me.  Were you thinking to
pass in some additional arguments?
> Will QSRV support pausing? This was added for DESY's hot-standby work; I
> don't see it as particularly important, but QSRV should probably display
> a warning message when someone tries to use it if it's not supported.
No plans.  I hadn't considered this as I've never paused RSRV.
Re: iocShutdown() hooks Andrew Johnson
Re: iocShutdown() hooks Michael Davidsaver
Prev: Build failed in Jenkins: epics-base-3.15-win64-test #112 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.15-win64-test #113 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: iocShutdown() hooks Andrew Johnson
Next: Re: iocShutdown() hooks Andrew Johnson
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
